Hey, I'm trying to rip the special features from season 1 of Star Trek TOS on blu ray. It seems like the special features that aren't featured in HD show up in the title tray, but the ones that are HD aren't loading?
This is what the title tray looks like: http://i.imgur.com/T3cpGiP.png
The episodes (4 of them) are there twice, and then there are little episode segments, as well as 2 dvd features. however, the HD features are missing. anyone have any idea if i'm doing something wrong? thanks.
Special Features Not Loading?
Re: Special Features Not Loading?
By HD do you mean the Star Trek Access Episodes?
If you do you should know that they're created through Picture In Picture, basically an SD 720x480 picture is overlayed on top of the actual episode, then there's a DTS Express Track that's overlayed on top of the audio. MakeMKV will just ignore the second Video Stream, it should pick up the DTS Express Track but doesn't for some reason. I THINK the first episode of Star Trek Access uses the same playlist file as the first episode of the show, at least the play list MakeMKV displays has the same name as the Playlist you can extract the Secondary Video Stream and DTS Track using EAC3To or MKVMerge. At the moment the best advice I can give is to use MakeMKV to create a full backup of the disc, search in the playlist folder using MediaInfo for the playlists containing a DTS Express Track, then use EAC3To to extract the DTS Express and Secondary Video Track. I posted an AVISynth script on the VideoHelp Forum that will let you combine the two video streams properly (the SD track is supposed to be disabled at various intervals, which I assume is an effect created through BD commands in the playlist), the audio will be more difficult, one guy managed to record the correct audio by playing it on a BD player and recording it on his PC, but if you're not up to that you'll have to find an audio editing program and mix the audio yourself (like the video, the audio mixing is supposed to change when the "access" components aren't active, but as far as I can tell there's no way to duplicate that properly). The final part of the equation is the PGS graphics which are also overlayed on top of the video. I think MakeMKV can get to that properly.
PS. When you're extracting the SD Video don't use MKVMerge, it seems to damage the VC-1 Track at the segment boundaries.
http://forum.videohelp.com/threads/3673 ... OS-Blurays
I double checked the features I'm looking at and it's not the Access Episodes. These are just common features, the one on this particular disc (disc 7) is just a featurette. 2 out of 3 of the featurettes appears, but this one doesn't. The only difference that I can tell is that the 2 features that do appear are not listed as HD in the informational booklet.
What is your minimum time setting for titles? I have mine set to 30 seconds, but the default is 120... so any feature shorter than that would not appear in the selection list. This setting is in the first tab (video) of the Preferences menu.
hi! thanks, i didn't know about this setting. i changed it but i still don't see the feature. is there a way to preview the titles before ripping them? maybe it's there and i'm missing it.
Enable debug logging and post the results of the scan portion here. See the link to the FAQ in my signature for how to do this.
Debug log started at Sun Nov 2 19:32:30 2014 , written by MakeMKV v1.8.14 darwin(x86-release)
001005:0000 MakeMKV v1.8.14 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/stephie/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE BP50NB40 1.00d" opened in OS access mode.
005050:0000 Evaluation version, 28 day(s) out of 30 remaining
DAFD=PAAAADAAAAEABDQkEFwECAQ==
DCE=hqH5IFWIgaLDwma1LigzlyHl+sMbcsTr5hPvX7O4z1FhwWYSVGYeuIr7UtxfP/Dv+0aauCNQPxuXSQc6MI4LkgEvbile4tDJPlfNu3OIdCpTvFQYvj84lK8O5t2VNBJl6m5EL1jDGd8w6krvDxl+RMN4ZMMSUUCdUg==
DCE=jnd+FR8y7nTaE0Pifs5uJeTXieHw1esfrOa89QGUmcZzMLqyNvFx/zXx6BvlC318Pkm0sddVTUpxUUqr8xlWFTHQgYasAKfh4tr+bDMRLqGMxkUzG9uMJ8rB3GKMay19h69mzkblAQz1oYT44+bMGbUiUzlTzox3Aw==
DISCID=7D77E1C853FBA64B3193A9553DA9D289107D3249
003308:0000 File 00000.mpls (angle 1) was added as title #0
003308:0000 File 00000.mpls (angle 2) was added as title #1
003308:0000 File 00001.mpls (angle 1) was added as title #2
003308:0000 File 00001.mpls (angle 2) was added as title #3
003308:0000 File 00002.mpls (angle 1) was added as title #4
003308:0000 File 00002.mpls (angle 2) was added as title #5
003308:0000 File 00003.mpls (angle 1) was added as title #6
003308:0000 File 00003.mpls (angle 2) was added as title #7
003307:0000 File 00009.mpls was added as title #8
003025:0000 Title #00017.mpls has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00018.mpls has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00019.mpls has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00016.mpls has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003307:0000 File 00010.mpls was added as title #9
003307:0000 File 00011.mpls was added as title #10
003307:0000 File 00036.m2ts was added as title #11
003307:0000 File 00037.m2ts was added as title #12
003307:0000 File 00160.m2ts was added as title #13
003307:0000 File 00161.m2ts was added as title #14
003307:0000 File 00162.m2ts was added as title #15
003307:0000 File 00163.m2ts was added as title #16
003307:0000 File 00164.m2ts was added as title #17
003025:0000 Title #00169.m2ts has length of 17 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00173.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00175.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00180.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00184.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00186.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00190.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00170.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00171.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003307:0000 File 00005.m2ts was added as title #18
003307:0000 File 00006.m2ts was added as title #19
003307:0000 File 00007.m2ts was added as title #20
003307:0000 File 00024.m2ts was added as title #21
003307:0000 File 00025.m2ts was added as title #22
003307:0000 File 00026.m2ts was added as title #23
003307:0000 File 00027.m2ts was added as title #24
003307:0000 File 00028.m2ts was added as title #25
003307:0000 File 00029.m2ts was added as title #26
003307:0000 File 00030.m2ts was added as title #27
003307:0000 File 00097.m2ts was added as title #28
003307:0000 File 00119.m2ts was added as title #29
