MakeMKV not recognizing my Panasonic UJ-120 external drive
bridaw
Post by bridaw »
Hello, I recently learned about MakeMKV so I purchased this Panasonic UJ-120 external drive:
http://www.amazon.com/s/ref=nb_sb_noss? ... B00E6HG1XI
I'm running OS 10.8.5 on a 3.4GHz i7 iMac. The mac will mount media just fine using this drive but it seems MakeMKV doesn't recognize this optical drive. Below is the log. It doesn't seem to matter if I launch the app before or after I mount the disc. I have the drive plugged directly into the back of the iMac instead of my powered hub. The OS and other apps seem happy with this optical drive but not MakeMKV. Is there anything I can do to make this drive work with MakeMKV?
Debug log started at Sat Nov  1 21:29:46 2014 , written by MakeMKV v1.8.14 darwin(x86-release)
001005:0000 MakeMKV v1.8.14 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/bd/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at B'\lb]kCBybw2~s0:121271456
005042:0000 The program can't find any usable optical drives.
003006:0000 Opening files on harddrive at /Volumes/DESPICABLE_ME
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at lrqlGf7-nu\M4^r@:213131939
001003:0020 DEBUG: Code 0 at lrqlGf7-nu\M4^r@:121265545
Re: MakeMKV not recognizing my Panasonic UJ-120 external dri
Post by mike admin »
Your drive returns bogus response to a certain SCSI command and MakeMKV thinks that it is broken. While this is a drive error, this is still probably a bug in MakeMKV.
Do you have access to a windows machine, either in VM or via bootcamp? I have to ask you to run a few tests for troubleshooting. Please reply to support@makemkv.com .
bridaw
Post by bridaw »
I have a copy of Windows XP SP3 I run within Parallels Desktop. I sent you email as well.
