Demo Version too old?
RealityBites
Post by RealityBites »
While trying to run MakeMKV tonight I got a popup saying
This DEMO version has is too old. Please download the latest version at http://www.makemkv.com
So I did.
I still got the popup. So I unistalled and reinstalled. Still getting the popup.
michelkenny
Re: Demo Version too old?
Post by michelkenny »
RealityBites
Already read that. Since the app exits after the pop-up, having the activation code doesn't exactly help.
Edited to add: found a workaround. Installed it on another machine, exported the registry setting, imported it on the machine with the BD drive
Post by mike admin »
Are you sure that you are running 1.5.0? Please recheck in help-about
RealityBites
Again, once that message popped up, the application exited, so it was impossible to check the version. There was no getting past that pop-up.
I was finally able to load it by installing it on another PC, exporting the registry information and importing it.
However, once it was installed it wouldn't decrypt the blu-ray I needed to re-rip. I ended up finding a copy of version 1.412 which works fine.
That sounds terrible. Are you sure that you have used 1.5.0 downloaded from this site? May I ask what kind of BD disc it was and how the program failed to handle it, failed to decrypt, failed to recognize the movie or failed in other way?
