changing file name
Mark0x01
changing file name
#1 Post by Mark0x01 » Sun Oct 26, 2014 11:11 pm
I have been moving a large number of dvd's to a nas to play with xbmc on a raspberry pi.
This app really speeds up the process.
No more scratched and lost dvd's :D
I trim down the selection to remove unwanted titles and languages.
Most end up being saved as tile00.mkv.
It would be nice to be able to set this before starting, unless there is a way I've missed.
Also, when I untick a top title branck, the lower ones remain selected (ticked)
Does this mean they are still selected ?
ndjamena
Re: changing file name
#2 Post by ndjamena » Mon Oct 27, 2014 12:52 am
Mark0x01 wrote:I have been moving a large number of dvd's to a nas to play with xbmc on a raspberry pi.
View | Preferences | General | (Check) Expert Mode
You can then find the File Name in the "Properties" Drop Down Box on the main GUI.
MakeMKV won't save tracks without putting them in a file, so if you uncheck a file it's track checkboxes become irrelevant.
Mark0x01
#3 Post by Mark0x01 » Fri Nov 28, 2014 10:13 pm
The problem is I usually save just the main movie, and in english only.
No other tracks, languages or subtitles.
The NAME property is correct, but the output file name is different, as it adds the track info.
e.g.
property NAME is HAPPY_FEET
file writes to HAPPY_FEET_t00.mkv
I really wanted HAPPY_FEET.mkv
ndjamena
#4 Post by ndjamena » Fri Nov 28, 2014 11:10 pm
You can click on the drop down box and change the file name, or you can write a batch script the rename them after the fact.
Set "NewName=%~n1"
if "%NewName:~-4,2%"=="_t" Set "NewName=%NewName:~0,-4%"
if NOT "%NewName%"=="%~n1" ren "%~f1" "%NewName%%~x1"
Assuming you're using windows.
You can add
Set "NewName=%NewName:_= %"
if you'd rather lose the underscores too.
