Lawrence of Arabia
wessongroup
Lawrence of Arabia
#1 Post by wessongroup » Thu Oct 23, 2014 7:39 pm
Can't get this one to work ...
Movies/MKV
MakeMKV v1.8.14 darwin(x86-release) started
Optical drive "BD-RE TSSTcorp BDDVDW SN-506BB SB00d" opened in OS access mode.
Title #00099.mpls has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00007.mpls was added as title #0
File 00102.mpls was added as title #1
Title #00999.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00095.mpls has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00096.mpls has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00002.mpls was added as title #2
Title 00001.mpls is equal to title 00007.mpls and was skipped
Title 00004.mpls is equal to title 00007.mpls and was skipped
File 00005.mpls was added as title #3
Title #00100.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00099.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00502.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00503.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00504.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00205.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #04999.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00097.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00098.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00208.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 3 titles into directory /Users/wileywesson/Movies/Larwance
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8670867456'
Error 'Scsi error - UNIT ATTENTION:POWER ON, RESET, OR BUS DEVICE RESET OCCURRED' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8671592448'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8671985664'
Error 'Scsi error - UNIT ATTENTION:POWER ON, RESET, OR BUS DEVICE RESET OCCURRED' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8672378880'
Error 'Scsi error - UNIT ATTENTION:POWER ON, RESET, OR BUS DEVICE RESET OCCURRED' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8673619968'
Error 'Scsi error - STATUS_05' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8673619968'
Failed to save title 0 to file /Users/wileywesson/Movies/Larwance/Lawrence_of_Arabia_(Restored_Version)_t00.mkv
Error 'Posix error - No such file or directory' occurred while creating '/Users/wileywesson/Movies/Larwance/Lawrence_of_Arabia_(Restored_Version)_t02.mkv'
Failed to save title 2 to file /Users/wileywesson/Movies/Larwance/Lawrence_of_Arabia_(Restored_Version)_t02.mkv
Error 'Posix error - No such file or directory' occurred while creating '/Users/wileywesson/Movies/Larwance/Lawrence_of_Arabia_(Restored_Version)_t03.mkv'
Failed to save title 3 to file /Users/wileywesson/Movies/Larwance/Lawrence_of_Arabia_(Restored_Version)_t03.mkv
0 titles saved, 3 failed
Error 'Scsi error - UNIT ATTENTION:POWER ON, RESET, OR BUS DEVICE RESET OCCURRED' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8666345472'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8668839936'
Error 'Scsi error - STATUS_05' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8669294592'
Error 'Scsi error - UNIT ATTENTION:POWER ON, RESET, OR BUS DEVICE RESET OCCURRED' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8669294592'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8667002880'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8667267072'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8667463680'
Error 'Scsi error - UNIT ATTENTION:POWER ON, RESET, OR BUS DEVICE RESET OCCURRED' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8667660288'
Error 'Scsi error - STATUS_05' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8667918336'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8667918336'
Error 'Scsi error - STATUS_05' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8666345472'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8666345472'
Saving 4 titles into directory /Users/wileywesson/Movies/*:Larwance
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8664969216'
Error 'Scsi error - STATUS_05' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8664969216'
Error 'Scsi error - UNIT ATTENTION:POWER ON, RESET, OR BUS DEVICE RESET OCCURRED' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8665300992'
Error 'Scsi error - STATUS_05' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8665430016'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8665890816'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8666087424'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8666351616'
Failed to save title 0 to file /Users/wileywesson/Movies/*:Larwance/Lawrence_of_Arabia_(Restored_Version)_t00.mkv
Error 'Scsi error - UNIT ATTENTION:POWER ON, RESET, OR BUS DEVICE RESET OCCURRED' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8665694208'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8666480640'
Error 'Scsi error - STATUS_05' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8666806272'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8666806272'
Error 'Scsi error - UNIT ATTENTION:POWER ON, RESET, OR BUS DEVICE RESET OCCURRED' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8666806272'
Failed to save title 2 to file /Users/wileywesson/Movies/*:Larwance/Lawrence_of_Arabia_(Restored_Version)_t02.mkv
Error 'Scsi error - UNIT ATTENTION:POWER ON, RESET, OR BUS DEVICE RESET OCCURRED' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8663396352'
Error 'Scsi error - STATUS_05' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8664053760'
Failed to save title 3 to file /Users/wileywesson/Movies/*:Larwance/Lawrence_of_Arabia_(Restored_Version)_t03.mkv
1 titles saved, 3 failed
Re: Lawrence of Arabia
#2 Post by Woodstock » Fri Oct 24, 2014 1:53 pm
Looks remarkably like the errors you get when the drive draws too much power and momentarily shuts down. A lot of users of USB-powered external drives have this issue when the drive is spun up to full speed, but they work fine when accessing the disk via applications that are "too slow" to run the drive at its full potential.
Is this an external drive? Is it powered by USB?
wessongroup
#3 Post by wessongroup » Sat Oct 25, 2014 12:18 am
Yes a LaCie USB 3 ...
All others disks have not had the problem ...
I washed it and then dried it very carefully and was able to play it, on the LaCie player, viewing through Blue-Ray Player® software
Thought I had it fixed and started trying to copy ... repeated tries with no success
Just thought I'd ask, I might try cleaning the "reader" in the player ... Thanks ... had forgotten to do that ... it has worked before for me
Thanks for your input ... will look into problems with the "hardware" first, then the media, lastly software, but don't think it is there
All other functions work, including the streaming feature ...
This is the only hic-up I've had in transferring the library on to an external drive, thus far
#4 Post by Woodstock » Sat Oct 25, 2014 2:15 am
If it's plugged into a blue USB3 port on the computer (or an externally-powered USB3 hub), power SHOULDN'T be a problem... USB3 has higher current available per device than USB2, which is where problems are frequent. With USB2 ports, you often have to use an external power supply OR a two-headed USB cable to get sufficient power to the drive.
Is this the only thing operating on the USB3 bus at the time?
wessongroup
#5 Post by wessongroup » Sat Oct 25, 2014 2:39 am
Yes, USB from the "player" into a Mac mini late 2012 ... 8GB ram/1TB HD, connected to an Apple Thunderbolt display using Apples cabling and on the Mac mini Thunderbolt out port that cable goes to a LaCie 3TB by Thunderbolt
The player is the only thing which is USB
The disk may be flawed ... Don't think it's hardware, at this time ... have done over 200 Blue-Ray disk's ... and this has been the only one that didn't go through the processing of the "data"
I just couldn't read the "log" and see anything which I could deciphed
Maybe cheaper and/or easier just to buy another copy ... before going any farther ... LOL
Thanks again
It's a great movie .... and in widescreen and 1080P on location ..
Update 10/28 ... After reading reviews on Amazon, saw there was a problem with some disk's ... order a new disk, got in yesterday ... and have just completed a transfer to .m4v with no problems
Not a hardware nor a software problem (MVK), rather a flawed disk by the mfg. ... smooth sailing :D :D
