and another fault
sanderdvd
and another fault
Post by sanderdvd » Fri Feb 06, 2009 3:03 pm
When trying to make a .mkv with one of my movies I get an error with the following log:
Opening dvd files on harddrive at C:/Documents and Settings/Movies/Gran Torino/
Calculated BUP offset does not match one in IFO header.
Cell 12 was discarded (structure protection?)
Title #0 was added (11 cell(s), 1:57:13)
Operation sucessfully completed
Saving 1 titles into directory C:/Documents and Settings/Movies/Gran Torino
FAILURE: Code 2042 at dT<g4|!'>%#vG$,0YKr:121262509
FAILURE: Code 0 at ;f+_[>8)/JL;7mskg'P-:213130444
FAILURE: Code 31518 at ;f+_[>8)/JL;7mskg'P-:213129639
Failed to save title 0 to file C:/Documents and Settings/Movies/Gran Torino/title00.mkv
0 titles saved, 1 failed
sanderdvd
Re: and another fault
Post by sanderdvd » Fri Feb 06, 2009 3:10 pm
and again another fault with another movie:
Opening dvd files on harddrive at C:/Documents and Settings/Movies/The Reader/
Title #0 was added (42 cell(s), 2:03:34)
FAILURE: Code 16683333 at Cx<4&zFTwH5zGO+SlsF:121261474
sanderdvd
Post by sanderdvd » Fri Feb 06, 2009 3:11 pm
and the next one :(
Opening dvd files on harddrive at C:/Documents and Settings/Movies/Slumdog Millionaire/
Title #0 was added (12 cell(s), 2:00:23)
FAILURE: Code 696 at wo<N&I n>"na2SpeP-+fe:29394827
FAILURE: Code 17219 at ;f+_[>8)/JL;7mskg'P-:213129639
Failed to decode audio/video data for title #0 - invalid mux or internal error, title skipped.
I think I ll have to wait for a more stable version. :D
sanderdvd
Post by sanderdvd » Fri Feb 06, 2009 3:17 pm
the next one.
Opening dvd files on harddrive at C:/Documents and Settings/Movies/Pride And Glory/
Cell 34 was discarded (structure protection?)
Title #0 was added (33 cell(s), 2:09:41)
Title #1 has length of 17 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 1 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 1 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 30 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 7 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 61 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 69 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Cell 1 was discarded (structure protection?)
FAILURE: Code 10551310 at A#[6PcF}.hlQ5{+y:213132744
FAILURE: Code 0 at P'Ebmx v!qzkeBM:29394666
CellWallk algorithm failed (structure protection is too though?), trying CellTrim algorithm
Cells 1-1 were removed form title start
Cells 7-8 were removed form title end
Title #8 was added (5 cell(s), 0:05:03)
Title #9 has length of 10 seconds which is less then minimum title length of 120 seconds and was therefore skipped
FAILURE: Code 2290 at ;f+_[>8)/JL;7mskg'P-:213129639
Failed to save title 0 to file C:/Documents and Settings/Movies/t00_Title_1.mkv
Post by mike admin » Fri Feb 13, 2009 10:11 am
All of these errors show that your VOB files (on hard drive) do not conform to DVD specification. What program did you use to create them? Did you use any transcoding tools? Also please try the latest version ( 1.3 ) and see if it still fails.
