Feature Request - Uncheck All
fxlgetrum
#1 Post by fxlgetrum » Sun Oct 19, 2014 5:30 pm
There are many bogus titles - small featurettes and the like - that can often take upwards of 20+ titles. Having to manually go through each separate title takes a while and if there were an "uncheck all" button, it would be easier to just deselect everything and then manually check the one or two titles we want. Whether the button unchecks the subselections (audio and subtitles) is up to you since the main checkbox determines whether or not the title saves.
tribunal88
Re: Feature Request - Uncheck All
#2 Post by tribunal88 » Mon Oct 20, 2014 11:48 am
Second that. This would be a nice feature.
ndjamena
#3 Post by ndjamena » Mon Oct 20, 2014 12:25 pm
I've heard this so many times it gets boring and I don't want to answer anymore.
RIGHT CLICK. It's MAGIC!
PaulCB
#4 Post by PaulCB » Tue Oct 21, 2014 3:31 am
ndjamena wrote:I've heard this so many times it gets boring and I don't want to answer anymore.
Though that doesn't remove it from all levels of all titles. You have to right click and uncheck at the top level then go into the title you want, right click there at the level of things you don't want selected like audio, etc.
cpt.surly
#5 Post by cpt.surly » Tue Oct 21, 2014 6:49 pm
You need to right-click uncheck all at each level.
You can also go to preferences -> Language tab and choose your preferred default language. This will have everything unchecked except your language and then you can "check add" additional languages or subs as needed.
I have been using makemkv for about a year now and just realised you can do the 2nd level un-check.
