Cannot convert...
kmmmn
Cannot convert...
Post by kmmmn » Fri Oct 17, 2014 10:04 pm
Never had a problem until today...Rio 2. This is the log - have tried multiple times...any ideas anyone?
Thanks.
Title #01930.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01931.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01932.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01933.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01934.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01936.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01937.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00251.m2ts was added as title #12
Title #01826.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.m2ts was added as title #13
Title #00256.m2ts has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00266.m2ts was added as title #14
File 00309.m2ts was added as title #15
File 00340.m2ts was added as title #16
File 00341.m2ts was added as title #17
Title #00249.m2ts has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00300.m2ts was added as title #18
Title #00301.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00258.m2ts was added as title #19
File 00259.m2ts was added as title #20
File 00267.m2ts was added as title #21
File 00268.m2ts was added as title #22
File 01875.m2ts was added as title #23
File 00801.m2ts was added as title #24
File 00802.m2ts was added as title #25
Title #01899.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00260.m2ts has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01901.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01938.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01939.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01940.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01941.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01942.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01945.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Users/Gateway/Downloads
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '40894464'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '41220096'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '41416704'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '41428992'
Same message a ton more times but with different numbers at the end.
