BD Drive Errors on all Blu Ray Discs
NCRobino
Post by NCRobino » Mon Oct 13, 2014 6:09 pm
I have the LG BD Rewriter WH10LS30 .
I've updated the firmware and drivers. The disc drive works with DVDs perfectly with MKV. If I put in ANY Blu Ray Disc I have, and I've tried The Conjuring & Evil Dead to name a few discs... I get the scsi error ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK .
I've followed the FAQ advice and up'd the attempts to 25. I've cleaned the discs. Nothing seem to work. Any other suggestions out there?
Rob
Re: BD Drive Errors on all Blu Ray Discs
Post by Woodstock » Mon Oct 13, 2014 6:18 pm
If you have debug logging turned on, start MakeMKV and insert one of the BDs in question. Let it try to open it. Shut down MakeMKV, and post the log file in a message here. Don't try attaching it, just click "Code" when you're editing the message, and insert it between the markers that will appear.
NCRobino
Post by NCRobino » Mon Oct 13, 2014 6:41 pm
This work?:
MakeMKV v1.8.13 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Rob/MakeMKV_log.txt
DEBUG: Code 101016576 at ;lA+Hf{6GF&5#0U[Pz:213132100
DEBUG: Code 101016576 at ;lA+Hf{6GF&5#0U[Pz:29393930
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading 'BD-RE HL-DT-ST BD-RE WH10LS30 1.02' at offset '524288'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading 'BD-RE HL-DT-ST BD-RE WH10LS30 1.02' at offset '1048576'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading 'BD-RE HL-DT-ST BD-RE WH10LS30 1.02' at offset '32768'
DEBUG: Code 0 at {.=}j=P@^gO;_9v=Gm-:213129777
Title #1 was added (14 cell(s), 1:51:43)
Title #2 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 was added (2 cell(s), 0:08:03)
Title #5 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 was added (7 cell(s), 0:14:04)
DEBUG: Code 233 at HHQY2vu+rMCTP9gTABnaf+fK:0
Saving 1 titles into directory C:/Users/Rob/Desktop/MKV Folder
1 titles saved
DEBUG: Code 3221225539 at T0j\=F4:N0X`rzm;:213134699
NCRobino
Post by NCRobino » Mon Oct 13, 2014 6:42 pm
The successful one in between was the DVD version of the Conjuring.
