Rip of Julie & Julia with DTS 5.1 Surroundhas audio problems
multimiler
#1 Post by multimiler » Sat Oct 11, 2014 10:33 pm
I've been using MKV for a while now to rip my library. However I'm having difficulty with the following titles:
  • * Julie & Julia (2009)
    *So I married an Axe Murderer
After ripping these to mv4, there are dead spots in the audio in the resulting mkv file. By "dead" I mean that the audio cuts out for a few seconds randomly
Here's the disk information for Julie & Julia:
OS device name: /dev/rdisk1
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E301
Serial number: MFDL050425WL
Bus encryption flags: 13
Highest AACS version: 35
Disc Information
Label: JULIE_AND_JULIA
Timestamp: 2009-10-16 11:05:15
Data capacity: 44.42 Gb
Disc type: BD-ROM
Number of layers: 2
I selected the DTS 5.1 Surround audio stream for extraction and ripped away... Here's the log:
MakeMKV v1.8.13 darwin(x86-release) started
Optical drive "BD-RE ASUS BW-12D1S-U E301" opened in DASPI v1.4 mode.
File 00001.mpls was added as title #0
Title #00102.mpls has length of 60 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00999.mpls has length of 60 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #01013.mpls has length of 133 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #01015.mpls has length of 133 seconds which is less than minimum title length of 500 seconds and was therefore skipped
File 01000.mpls was added as title #1
Title #00099.mpls has length of 400 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00000.m2ts has length of 14 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00081.m2ts has length of 60 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00082.m2ts has length of 0 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00083.m2ts has length of 0 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00104.m2ts has length of 9 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00502.m2ts has length of 5 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00503.m2ts has length of 5 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00504.m2ts has length of 5 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00205.m2ts has length of 5 seconds which is less than minimum title length of 500 seconds and was therefore skipped
File 00539.m2ts was added as title #2
File 00541.m2ts was added as title #3
Title #00542.m2ts has length of 62 seconds which is less than minimum title length of 500 seconds and was therefore skipped
File 00543.m2ts was added as title #4
Title #00544.m2ts has length of 254 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00545.m2ts has length of 158 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00546.m2ts has length of 290 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00547.m2ts has length of 344 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #04999.m2ts has length of 30 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #05002.m2ts has length of 326 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #05003.m2ts has length of 146 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #05004.m2ts has length of 134 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #05006.m2ts has length of 122 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #05007.m2ts has length of 144 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #05008.m2ts has length of 128 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #05009.m2ts has length of 137 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #05010.m2ts has length of 150 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #05011.m2ts has length of 150 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #05012.m2ts has length of 152 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #05013.m2ts has length of 97 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #05015.m2ts has length of 66 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #05017.m2ts has length of 66 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #05019.m2ts has length of 8 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #05020.m2ts has length of 151 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Saving 1 titles into directory /Users/srmadsen/Movies/Julie and Julia
Forced subtitles track #3 turned out to be empty and was removed from output file
Forced subtitles track #5 turned out to be empty and was removed from output file
1 titles saved
Re: Rip of Julie & Julia with DTS 5.1 Surroundhas audio prob
#2 Post by Woodstock » Sat Oct 11, 2014 11:14 pm
Color me confused, but...
MakeMKV doesn't rip to m4v files.
What are you playing the files on that has problems with the audio? Is your player compatible with the audio format chosen?
multimiler
#3 Post by multimiler » Sun Oct 12, 2014 9:14 pm
Thanks for pointing out my error. I'm ripping BluRay to MKV and then using Handbrake to convert to MP4. The audio drops occur in both MKV and MP4 files. I'm using the Mac Blu-Ray Player to play both MKV and MP4 on my macbook. I'm beginning to wonder if the MKV and MP4 files are fine and that the real problem lies with the Blu-Ray Player.
ndjamena
#4 Post by ndjamena » Sun Oct 12, 2014 10:06 pm
You could go into preferences and check 'show AV Synchronization Messages' and see if that tells us anything interesting. But Julie and Julia has been around for a while and I doubt no one would have noticed gaps in the audio.
#5 Post by Woodstock » Mon Oct 13, 2014 12:58 am
If you suspect the player, go to videolan.org and download VLC for the Mac. It won't play EVERYTHING, but it will come closer than most applications.
