Spaceballs
Henrik
Spaceballs
Post by Henrik »
Finally got Spaceballs on something not VHS, but it doesn't like MakeMKV...
Log:
Debug log started at Thu Oct 09 18:59:00 2014 , written by MakeMKV v1.8.13 win(x64-release)
001005:0000 MakeMKV v1.8.13 win(x64-release) started
001004:0000 Debug logging enabled001003:0020 DEBUG: Code 2 at T0j\=F4:N0X`rzm;:213137827
001003:0020 DEBUG: Code 101019395 at ;lA+Hf{6GF&5#0U[Pz:213132100
001003:0020 DEBUG: Code 101019395 at ;lA+Hf{6GF&5#0U[Pz:29393930
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'BD-ROM HL-DT-ST BDDVDRW CA10N VC1E' at offset '1048576'
003028:0000 Title #1 was added (17 cell(s), 1:32:07)
003025:0000 Title #2 has length of 153 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #3 has length of 8 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #4 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory C:/Video/SPACEBALLS
001003:0020 DEBUG: Code 3221225628 at "F^}@p<jtU`9@o;!j=JU(rhL-:121263521
001003:0020 DEBUG: Code 3221225628 at cE<&o39<YXZ75Rhg:29393953
002003:0000 Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '111966208'
002003:0000 Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '112490496'
001003:0020 DEBUG: Code 0 at "ZH]x0HSvTFO!`+%iXP|:121263038
001003:0020 DEBUG: Code 0 at <q^pfEOujf!KP/u|+{\:121261750
001003:0020 DEBUG: Code 0 at "ZH]x0HSvTFO!`+%iXP|:213130559
001003:0020 DEBUG: Code 54927 at "ZH]x0HSvTFO!`+%iXP|:29393286
001003:0020 DEBUG: Code 0 at G\gI1,k\,9|4EyRwPD|%K:213135090
005003:0000 Failed to save title 0 to file C:/Video/SPACEBALLS/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Thu Oct 09 19:08:01 2014
It also fails on my Monthy Pythons Flying Circus, but I'll get those logs another day.
Re: Spaceballs
The drive is having problems reading the disk. Often, the "READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION" error is caused by this, too.
If it happens on a single disk, it is probably the disk with a problem, such as a scratch or fingerprint. Cleaning (and possibly waxing) the surface can help that.
If multiple disks have similar failures, I suggest cleaning the DRIVE, and retrying.
Henrik
Re: Spaceballs
Post by Henrik »
It's happening with only a few DVDs, so I guess it could be bad ones - odd thing is, that it's only a few rather new ones it happening to. I guess quality ain't what it used to be...
