can't read: 7770749E1E - Real Humans / DVD - CSS/CPPM protec
Peter
Post by Peter »
sadly it isn't possible to tip thios disc.
Is there any know workaround?
i couldn't upload the log files, because: "Sorry, the board attachment quota has been reached."
The error was:
MakeMKV v1.8.13 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\mFuSE/MakeMKV_log.txt
Title #2 has length of 16 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #3 was added (1 cell(s), 0:13:20)
Cells 20-end were skipped due to cell commands (structure protection?)
Title #4 was added (19 cell(s), 2:55:16)
Cells 21-end were skipped due to cell commands (structure protection?)
Cells 7-end were skipped due to cell commands (structure protection?)
Title #5 was added (6 cell(s), 0:58:29)
Cells 8-end were skipped due to cell commands (structure protection?)
Title #6 was added (7 cell(s), 0:58:22)
Cells 9-end were skipped due to cell commands (structure protection?)
Title #7 was added (6 cell(s), 0:58:25)
Audio stream #0 looks empty and was skipped
Re: can't read: 7770749E1E - Real Humans / DVD - CSS/CPPM pr
Not seeing any rip errors there - It looks like it found a 13:20 "extra", a 2:55:16 "all episodes" file, and three 58 minute "single episode" files. It looks like a typical scan of a lot of modern DVD, but there is nothing about the actual rip failing.
What happened when you clicked on the "Save to MKV" button?
