Wolf of Wall Street
rubychrome
Wolf of Wall Street
Post by rubychrome » Sun Oct 05, 2014 8:59 am
Morning Makers of Fine Software,
tried ripping Mononoke last week but kept getting errors. Thought it was because Ghibli is distributed by big D. Then this week I cannot get Wolf of Wall Street to rip for the heck of it.
MBA mid 2012.
Samsung BD SE-506
latest MKV
DASPI installed
here's the dump:
Debug log started at Sat Oct  4 20:44:06 2014 , written by MakeMKV v1.8.13 darwin(x86-release)
001005:0000 MakeMKV v1.8.13 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/Lobsta/MakeMKV_log_1.txt
002014:0000 Optical drive "BD-RE TSSTcorp BDDVDW SE-506BB TS00" opened in DASPI v1.4 mode.
005072:0000 Backing up disc into folder "/Volumes/DESKBENZ/Raw"
DAFD=PAAAADAAAAEABDQkEHwECAQ==
DCE=8vEraQQYeps7hrN1qS6Of+ATASzFrQX58kqptaxZKP2tddpfUo45t9Ozczo+yrj28G+H7zWFeFs4ZcBl2dFvWcVZrxpk8FjP/n5zyZqZiXpZ4D/WEMz2iJx1agx2JvWc9UmNYaZUBle7dlGNFfF0SveGn7aoIrB0/w==
DCE=aTxkixoB5jwHaNF8Z4dC8h338zA3DQcRu51NBlsLeN31HhIHlf3XGqRrfqz0cVI5jwhagUybropuyU0XCcu596eMBsgVASzGAoF5l70gSh5mjSNrBZavja2kAWhAbKShHZBLEY9sm6+cLnCbEyo4XPDHvkIlIfUZkg==
001003:0020 DEBUG: Code 1073741829 at .bGAAUy}8<xUa1v{:29393953
001003:0020 DEBUG: Code 2 at 7ilYPwoy(Kn0FyS::213137827
001003:0020 DEBUG: Code 513 at ov@]?g#9:?k:"jlb:213138333
001003:0020 DEBUG: Code 4097 at ov@]?g#9:?k:"jlb:213138333
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00023.m2ts' at offset '23894814720'
001003:0020 DEBUG: Code 0 at JAT+vc%Xk*Qfx)RKzTG:213134469
001003:0020 DEBUG: Code 0 at RwD]ir*0mE?Ob6smighW:121265108
005069:0080 Backup failed
005080:0204 Backup failed.
Thoughts? Ideas? Should I try another BD? Is my drive spent? Is it the KEXT? Is it Make MKV? The Disc itself?
Appreciate your thoughts.
/B.
Re: Wolf of Wall Street
Post by Woodstock » Sun Oct 05, 2014 3:36 pm
That's the key, there. The drive says it can't read part of the disk.
If it happens on a lot of disks, it may be the drive. If it is only one file on one disk that is failing, it is most likely the disk itself.
In this case, you might be able to Open the disk (rather than back it up), and save the tracks to individual MKV files. The file 00023.m2ts could be something unimportant, and not part of the movie itself.
Badly mastered disks are not unheard of. They may play acceptably in a stand-alone player that is programmed to ignore bad spots, but they fail when you try to get an exact copy of the contents, like you do when you're ripping. Exchanging disks like this is your best option, and hoping you don't get one from the same batch.
