Backup of "Bears" and "The Rover" both hang
Re: Backup of "Bears" and "The Rover" both hang
#16 Post by Woodstock » Sun Oct 05, 2014 12:50 am
There are several ways to tell Windows that you want to select what drivers to include during the boot process.
Because links in messages can cause delays here, go to google and enter the query "selective boot windows"; one of the first to come up will be a Microsoft page titled "Run Selective Startup using System Configuration".
johng
#17 Post by johng » Wed Oct 08, 2014 2:32 pm
Got 2 more movies in "Obvious Child" and "Dom Hemingway" and was able to make backups of both. Those are both new releases so looks like the Toshiba UDF driver was definitely the issue.
johng
#18 Post by Woodstock » Wed Oct 08, 2014 3:47 pm
I do not know what your usage is, but... if the only use of the BD drive is to rip disks, you can remove the UDF driver.
johng
#19 Post by johng » Wed Oct 08, 2014 6:00 pm
I have it disabled. I originally installed it because VLC and BDInfo couldn't read the bluray drive. I was using BDInfo with AnyDVD (trial version) to rip disks. Since MakeMKV doesn't need the driver then I just backup the disc first and then point BDInfo at the backup version and it works fine. So probably won't need to enable the driver in the future.
johng
Woodstock wrote:I do not know what your usage is, but... if the only use of the BD drive is to rip disks, you can remove the UDF driver.
