Cannot Rip SKYLINE blu ray
diy_darryl
Post by diy_darryl »
I have a version labeled "rental" that I bought from a Blockbuster that was going out of business. Have successfully ripped others that also said "rental" but wanted to throw that out there in case it mattered.
Cannot get a bug report because makemkv hangs up and freezes. It says a file is corrupt or invalid at offset xxxxxxx attempting workaround.
The disc has no visible scratches or smudges and I have tried cleaning it. Any suggestions?
EDIT:I have figured out that I need to enable debugging, will post results when I get a chance.
diy_darryl
Re: Cannot Rip SKYLINE blu ray
I guess I am an idiot! I cannot open the debug file because it says it is in use. I have closed makemkv
HELP?
EDIT: Closed a task in task manager and now can open file but it is a pile of run-on statements and over 5000 pages long.
GEEZ! I am mostly handy with computers but have no clue how to give you the file you need for troubleshooting????
If you can post a sampling of the messages being generated, it would help.
I keep Pledge furniture polish handy to deal with disks that others have handled. It cuts grease from fingerprints very well, and fills in minor scratches. Always use a SOFT COTTON CLOTH to wipe it down with, though...
diy_darryl
Cleaned the disc with Pledge and still no-go.
There are hundreds of pages in my debug file of similar text.
Here is a snapshot of the last page right before I aborted the process after MakeMKV hung up (froze).
004004:0000 The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 13248909312, attempting to work around
tp=PA9aT4ZSVgyfam8Rpc09eqdQJ3U0rbIaqpM6hffstwIkAwj8yoTtOsILGxYl2w192AhD3VAKmEw9lEFmct/X76e9egl9fb76E/5UtW9saFTypNmQx2PRIXQIR9dn9pYXnRlrGLGaaR5O74mr5BplqVqi5TAtr5fIRVyPW6bV8z053vbBwhgDExJX4sewsN1q4ZTiPedmzUIp+NBqhpYgpT4CFUKYPp/baz/InvNWLuvWd476h4cHMI6y1Ci4=
001003:0020 DEBUG: Code 0 at +[AxAi-:{-b^HP/LbT{Z:29394574
tp=PKyrFmgPWk+GUlYMn2pvEaXNPXqnUCd1NK2yGqqTOoX37LcCJAMI/MqE7TrCCxsWJdsNfdgIQ91QCphMPZRBZnLf1++nvXoJfX2++hP+VLVvbGhU8qTZkMdj0SF0CEfXZ/aWF50ZaxixmmkeTu+Jq+QaZalaouUwLa+XyEVcj1um1fM9Od72wcIYAxMSV+LHsLDdauGU4j3nZs1CKfjQaoaWIKU+AhVCmD6f22s/yJ7zVi7r1neO+oeHBzCOstQou
tp=Pcik+vJyraIulnEzJYnR8r37BWQsfv4lAenglOH3W0IDqMObgyBmzwFW21PMnThMpJVjfDo2sE1bcQWnvn7TokQ7rKFwuASs/RKJ3RrdSY60ARjbySI3bsr25n3MZVUso2Z1xF7DYr1QJtd/NzmjCFK/dTto1Qoe7lHVbXpk9Dbq1AkIydx6+Vz6R2YogHrirAt+/foJVcLg/ZC+PUVHcOF7DCryDftRV93yV/em/ySq8MtVdYVGg5VCYxDU=
tp=PfNvoAnIpPrycq2iLpZxMyWJ0fK9+wVkLH7+JQHp4JTh91tCA6jDm4MgZs8BVttTzJ04TKSVY3w6NrBNW3EFp75+06JEO6yhcLgErP0Sid0a3UmOtAEY28kiN27K9uZ9zGVVLKNmdcRew2K9UCbXfzc5owhSv3U7aNUKHu5R1W16ZPQ26tQJCMncevlc+kdmKIB64qwLfv36CVXC4P2Qvj1FR3Dhewwq8g37UVfd8lf3pv8kqvDLVXWFRoOVQmMQ1
tp=P1NaWqUswe1JTOfX0lUS9taFmSytJS4e8Tq6VtS5PuSoquEpNrig6cEzB3vFxM9cgZX2uKrgS0g3j8e5iApTa44K3ycdk8OuPe03E2GBGDBEogxn5JyRWf49FIvwFOWom0vDLnSGGf3nTdl4lNenOTldXZXDzI50CYdWHLZJg75qpKw00ODAR/Cu1B3U5Y60XC0u+fHK22/NC/JwazNCpv/jOhYMlcQwsJFHsXv8OFaLDYF3igvmUmPM36zA=
tp=P5uDLBtTWlqlLMHtSUzn19JVEvbWhZksrSUuHvE6ulbUuT7kqKrhKTa4oOnBMwd7xcTPXIGV9riq4EtIN4/HuYgKU2uOCt8nHZPDrj3tNxNhgRgwRKIMZ+SckVn+PRSL8BTlqJtLwy50hhn9503ZeJTXpzk5XV2Vw8yOdAmHVhy2SYO+aqSsNNDgwEfwrtQd1OWOtFwtLvnxyttvzQvycGszQqb/4zoWDJXEMLCRR7F7/DhWiw2Bd4oL5lJjzN+sw
001003:0020 DEBUG: Code 0 at &I&],x"-Fqv(W9ji:29396529
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading '/BDMV/STREAM/00010.m2ts' at offset '13248915456'
001003:0020 DEBUG: Code 0 at "ZH]x0HSvTFO!`+%iXP|:121263038
001003:0020 DEBUG: Code 0 at +[AxAi-:{-b^HP/LbT{Z:121261888
001003:0020 DEBUG: Code 0 at "ZH]x0HSvTFO!`+%iXP|:29394482
001003:0020 DEBUG: Code 6469197 at "ZH]x0HSvTFO!`+%iXP|:29393286
001003:0020 DEBUG: Code 0 at G\gI1,k\,9|4EyRwPD|%K:213135090
005003:0000 Failed to save title 0 to file H:/Movies3/Skyline (2010)/Skyline_t00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Sun Oct 05 20:52:09 2014
Mike will have to look at the debug messages to determine what MakeMKV was trying at each of the work-around messages.
Post by mike admin »
Please try making a full disc backup first, and see if any hashcheck errors show up.
diy_darryl
Thanks Mike, I will try that. Have never tried a full backup, I'll see if I can figure out how to do that. Will post back after I get a chance to try.
diy_darryl
Ok, The backup failed. Here is what the main screen shows. I am assuming I just need to toss the disc in the trash.
Backing up disc into folder "G:\temp"
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00010.m2ts' at offset '2871656448'
DEBUG: Code 0 at Mi$}]|RZjL>HSZ^S:M5:213134469
DEBUG: Code 0 at )FXScRDQ3`Hjx}m><Psv:121265108
Backup failed
Try the clean-and-wax route before you give up... It's worked for me on a lot of "Used - good" disks I purchased through Amazon.
And there's always polishing - If you don't have access to proper equipment, I've used tooth paste to polish out disks well enough to rip them once. After that, they go into storage, with a "fresh, minty smell". :)
