The Big Bang Theory Season 7
jhodgesatmb
#1 Post by jhodgesatmb » Fri Sep 26, 2014 11:41 pm
I received The Big Bang Theory, Season 7 from Amazon last week. I went to encode it like I always do and found that there were only 8 episodes on each of the 2 disks. I encoded them anyway and put them on my DROBO. Amazon was only too happy to send out another set, which I received today. Same problem. So I decided to watch one of the episodes I had encoded, and it was ALL messed up. So I put the blu-ray disk into the player and found that it had all 12 episodes and they are fine.
So MakeMKV was not only unable to encode them, it was unable to even read the disk properly. Has anyone encountered anything like this.
Encoded with MakeMKV, v 1.8.11, but have since updated to v 1.8.13 and the same problem exists in this version.
Jack Hodges
Rydsen
Re: The Big Bang Theory Season 7
#2 Post by Rydsen » Sat Sep 27, 2014 2:00 pm
Odd. I bought Season 7 from Target last week and both discs showed all 24 episodes and encoded just fine so I know it's not endemic to all Season 7 sets.
#3 Post by Woodstock » Sat Sep 27, 2014 2:43 pm
Debug logs would be helpful, of course. Check the link in my signature for how to generate them, if you don't have debug logging already turned on (I always leave it on).
DrPaul
#4 Post by DrPaul » Tue Sep 30, 2014 10:28 am
I also received mine from Amazon 8-82929-42211-1 is the bar code on the case; 8-83929-37342-0 is on the cardboard sleeve.
I get a message that the volume key is unknown for this disc.
This is v1.8.13 on an iMac running Mavericks (10.9.4); I get the same message running v1.8.13 Windows 7 in a VM on the same machine.
See below for the log ... I got a 'Sorry , the board attachment quota has been reached' when I tried to add the log file.
Debug log started at Tue Sep 30 09:46:21 2014 , written by MakeMKV v1.8.13 darwin(x86-release)
001005:0000 MakeMKV v1.8.13 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/drpaul/MakeMKV_log_1.txt
002014:0000 Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHB" opened in DASPI v1.4 mode.
002014:0000 Optical drive "HD-DVD-ROM HL-DT-ST BD-RE  GGW-H20L YL05" opened in DASPI v1.4 mode.
DAFD=PAAAADAAAAEABDQAEAQEBAQ==
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..018EC2557EC6D8CFFE756144ACEC6156396 to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
001003:0020 DEBUG: Code 0 at "'+HZ6I};o~C{"Rvc:213130743
001003:0020 DEBUG: Code 0 at cwooqQ&S1W&`(*wUMv:29395218
001003:0020 DEBUG: Code 0 at cwooqQ&S1W&`(*wUMv:29394643
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..09E9D1DDFA5AAC6D216434E4B348C7FABED to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
001003:0020 DEBUG: Code 1 at cwooqQ&S1W&`(*wUMv:29394643
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..00F2F32F3272197B2CBEF8F21F4896ED87C to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
001003:0020 DEBUG: Code 2 at cwooqQ&S1W&`(*wUMv:29394643
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0EAACB852C7BC1927250E886139EC6522BD to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
001003:0020 DEBUG: Code 3 at cwooqQ&S1W&`(*wUMv:29394643
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0EF85D709F37E43EA441B40B56D0A01AD01 to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
001003:0020 DEBUG: Code 4 at cwooqQ&S1W&`(*wUMv:29394643
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0EC7B938E529FE9914C948853E9C48AD208 to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..02F3F811CEE1ADA97542D5C191566005C49 to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..02CB8A4486F241C1D6754ED7BD16BCBCACD to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..02C800AC785CCD3DF5DA92264DCE91BA345 to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0D6F452D4CA8374E5DC82C244A4077155D9 to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0DB4238B13C68B8A73242083B247C2361A6 to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0539A6E5561CA0C9D793766BC88EBAE8118 to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0EC9C954469150B1F5026E0DFB95E470361 to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0E4FB3157FBB66A9D4C0788345F9D6D110D to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0F5988B756F62026A482371D6178D3F334E to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..013957248D02785F4FCDEAB84A9672DDDEA to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
DEBUG: Code 0 at "'+HZ6I};o~C{"Rvc:213130283
001003:0020 DEBUG: Code 0 at cwooqQ&S1W&`(*wUMv:121264487
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..054AD2F188C363AE532E465B7B7EFF384D6 to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0F0C734A1304B205BA2F4FC8510791EF009 to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..00A0213B1C862402DC37A140CE81D6F3903 to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0191044DB563B034569BDD2835951F0BA33 to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..05488CDDEDD4268FD8F7B3BD0D7BE5180FC to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..082E1963EB193BF0D0BEA62D72B1A638558 to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0BEB7984A42D85289C2718169B5FA57F8DA to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..004413BDACF7214E8A9C258FC294C1CDB08 to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..09B38651E69B7C7B19946BF40E51F0FACB9 to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0D634E8AF6372B7D500D88CA666F154EBDD to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0C6EF405707D1BB6C9BAE214E34A00C169A to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0768E8407F2E5B4FDBD56B7997C35D1103D to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0D63E29217AEFAF51C53C342008A13AB8B8 to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..01F7DE05EBCEDA051B8353256CC5B3298F7 to device 'DASPI:IODASPIService:429cf03c7cde7b5a:'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003341:0000 Highest AACS version is v47 , MKB saved as /Users/pgorman/.MakeMKV/MKB_v47_TRANSCENDENCE.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at %]X7{43tJMD{{B)W:213131962
001003:0020 DEBUG: Code 0 at %]X7{43tJMD{{B)W:29397357
Application exited at Tue Sep 30 09:54:17 2014
#5 Post by mike admin » Tue Sep 30, 2014 9:33 pm
Can you think of any other recently released disc you've inserted into the drive prior to that one?
zoomster
#6 Post by zoomster » Thu Oct 02, 2014 6:08 pm
I'm having the exact same problem. Anyone figure this out?
DrPaul
#7 Post by DrPaul » Sat Oct 04, 2014 12:24 am
I've been adding a lot recently as a whole bunch of TV and movie pre-orders have arrived from Amazon... Godzilla 3D was recent, Walking Dead Season 4, Person of Interest Season 3, Once Upon A Time Season 3, Supernatural Season 9, Homeland Season 3, Revolution Season 2, Sleepy Hollow Season 1. I just came back from visiting family in the UK and added Utopia Season 1, Demons Season 1, a bunch of David Attenborough 3D documentaries... it's hard to say.
jhodgesatmb
#8 Post by jhodgesatmb » Sat Oct 11, 2014 3:14 pm
I was unable to upload files (got an error that the board quota was full), but here is the log file from my encoding run:
Debug log started at Sat Sep 27 17:35:15 2014 , written by MakeMKV v1.8.13 darwin(x86-release)
001004:0000 Debug logging enabled, log will be saved as /Users/jackhodges/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHBd" opened in OS access mode.
002010:0000 Optical drive "BD-RE PIONEER BD-RW BDR-205 1.08d" opened in OS access mode.
001003:0020 DEBUG: Code 0 at N9GVLn9h(UR9}RZW,c~w1X|&]:121263153
DEBUG: Code 0 at }/[l-S~PVF]'ZN!j69"e1JITi:29394160
DAFD=PAAAADAAAAEABDQUEAQEBAQ==
DCE=8nTUf2I18YFNB3IJWNHKPsJEPECbqOeRiPOLFWT6/fsb1m0LczmO+avoRUyiQF0/qbkGu2AOY36p2xW1LdIcKtCZxDhnro26mh/7yNc2ZrULTWOgp1xp0Hhdm/6KIeWJbzm+kPY7hKJINuTwBR6RlM55ZRQaYwNMRQ==
DISCID=1DDA66BCD5E9E8C0B8DC807D864FA10B7AD76B0C
003025:0000 Title #00000.mpls has length of 8 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003307:0000 File 00062.mpls was added as title #0
003307:0000 File 00061.mpls was added as title #1
003025:0000 Title #00060.mpls has length of 1178 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00059.mpls has length of 1159 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003307:0000 File 00058.mpls was added as title #2
003025:0000 Title #00057.mpls has length of 1181 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003307:0000 File 00056.mpls was added as title #3
003025:0000 Title #00055.mpls has length of 1144 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003307:0000 File 00054.mpls was added as title #4
003307:0000 File 00053.mpls was added as title #5
003307:0000 File 00052.mpls was added as title #6
003307:0000 File 00051.mpls was added as title #7
003025:0000 Title #00009.mpls has length of 50 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00008.mpls has length of 29 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00007.mpls has length of 340 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003307:0000 File 00018.m2ts was added as title #8
003025:0000 Title #00031.m2ts has length of 11 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00030.m2ts has length of 19 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00999.m2ts has length of 4 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 10 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 50 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 29 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 10 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 23 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 340 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00040.m2ts has length of 4 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 421 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 209 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 0 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00310.m2ts has length of 1178 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00309.m2ts has length of 1159 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00307.m2ts has length of 1181 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00305.m2ts has length of 1144 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00038.m2ts has length of 4 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00901.m2ts has length of 15 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00900.m2ts has length of 15 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00037.m2ts has length of 4 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00032.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00036.m2ts has length of 4 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00035.m2ts has length of 1 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00034.m2ts has length of 9 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00033.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
DCE=afM7mmUdd0mpgPcIjYT9p564+fJ0+ffHX+Wuz+OHOly33F6S0ZzUNyQ06nkqS0Lg1nAhMf90GqiR9o34Q+HkNErie1wSLWTIRnQgO2RIx4H/VdsJX2vCT2ZlHW1tE9KQmEy9P6WYt3nj0sFjK530dJqEBScFUdPxQA==
003025:0000 Title #00000.mpls has length of 8 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003307:0000 File 00060.mpls was added as title #2
003307:0000 File 00059.mpls was added as title #3
003307:0000 File 00058.mpls was added as title #4
003307:0000 File 00057.mpls was added as title #5
003307:0000 File 00056.mpls was added as title #6
003307:0000 File 00055.mpls was added as title #7
003307:0000 File 00054.mpls was added as title #8
003307:0000 File 00053.mpls was added as title #9
003307:0000 File 00052.mpls was added as title #10
003307:0000 File 00051.mpls was added as title #11
003025:0000 Title #00009.mpls has length of 50 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00008.mpls has length of 29 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00007.mpls has length of 340 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003307:0000 File 00018.m2ts was added as title #12
003025:0000 Title #00031.m2ts has length of 11 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00030.m2ts has length of 19 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00999.m2ts has length of 4 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 10 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 50 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 29 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 10 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 23 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 340 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00040.m2ts has length of 4 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 421 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 209 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 0 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00038.m2ts has length of 4 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00901.m2ts has length of 15 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00900.m2ts has length of 15 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00037.m2ts has length of 4 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00032.m2ts has length of 5 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00036.m2ts has length of 4 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00035.m2ts has length of 1 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00034.m2ts has length of 9 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00033.m2ts has length of 5 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
005014:0000 Saving 12 titles into directory /Users/jackhodges/Movies/MyTV/THE BIG BANG THEORY SEASON 7 (2013)
004001:0000 Forced subtitles track #5 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #7 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #9 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #11 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #13 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #15 turned out to be empty and was removed from output file
005005:0080 12 titles saved
005036:0104 Copy complete. 12 titles saved.
DCE=DEkxGQF2vivZdqxF9aAjSdMxaHt4dvbyKiim9UqXnoPlT5GM7fiEi/UX4FzB3N9DJZYo7LqyvevcZqAcAj44xMoeW3+QvfmIBxsT2pkt8G75TZYprSUAnRnFkEgfguThD9NWIb3FIaebC8JRz58RvhwPmiyA7sUwhg==
DISCID=CF57D4B3DF86329DE1D98A40769C3C137BB9A295
003307:0000 File 00074.mpls was added as title #0
003307:0000 File 00073.mpls was added as title #1
003307:0000 File 00071.mpls was added as title #2
003307:0000 File 00070.mpls was added as title #3
003307:0000 File 00069.mpls was added as title #4
003307:0000 File 00068.mpls was added as title #5
003307:0000 File 00067.mpls was added as title #6
003307:0000 File 00072.mpls was added as title #7
003307:0000 File 00066.mpls was added as title #8
003307:0000 File 00064.mpls was added as title #9
003307:0000 File 00065.mpls was added as title #10
003307:0000 File 00063.mpls was added as title #11
003025:0000 Title #00017.m2ts has length of 966 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 915 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 339 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 188 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 531 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Application exited at Sun Sep 28 15:08:59 2014
and here is a link to the photograph I took when trying to play one of the episodes. All of the episodes I tried to view looked similar though. It would band like this for a second or two and then be ok for a few seconds:
http://arbor-studios.com/xfer/tvbandingonbbt7.png
Jack
MakeMKV Version v1.8.13
ENCODING machine: iMac 27 mid 2012, OS X 10.8.5
storage: DROBO 5D
streaming software/machine: PLEX, Mac MINI, OSX 10.9
