current beta key
chooch
current beta key
Post by chooch » Tue Sep 30, 2014 1:18 am
Anyone having issues with the one posted here?
http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
It quit working on 1.8.13
Re: current beta key
Post by Woodstock » Tue Sep 30, 2014 1:45 am
Yes, since this is the end of September, Mike has to generate a new key.
In the mean time, you can get MakeMKV working one of two ways - set your system DATE back to 9/28, start MakeMKV (no need to change the time), then restore the date to the proper day, or buy a key that doesn't expire.
It should only be a day or two before Mike updates the beta key.
chooch
Post by chooch » Tue Sep 30, 2014 4:25 am
Thank you very much for the info.
anubisq1911
Post by anubisq1911 » Tue Sep 30, 2014 10:46 am
Wish i would have saw this last night. Thanks for the workaround. Good to know for the future. Thanks!
deathtical
Post by deathtical » Tue Sep 30, 2014 7:57 pm
Woodstock wrote:buy a key that doesn't expire
How do you do this? I looked all over the main site and the FAQ and couldn't find a way to buy a key. Thanks
Post by Woodstock » Tue Sep 30, 2014 8:32 pm
The "buy" link is not the most obvious one on the site; I don't remember ever seeing a direct link to it on the site.
Within the program itself, Help->Purchase takes you to it... And the link is:
http://www.makemkv.com/buy/
deathtical
Post by deathtical » Wed Oct 01, 2014 12:14 pm
