Anyone having issues with the one posted here?
http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
It quit working on 1.8.13
current beta key
Re: current beta key
Yes, since this is the end of September, Mike has to generate a new key.
In the mean time, you can get MakeMKV working one of two ways - set your system DATE back to 9/28, start MakeMKV (no need to change the time), then restore the date to the proper day, or buy a key that doesn't expire.
It should only be a day or two before Mike updates the beta key.
chooch
Thank you very much for the info.
anubisq1911
Wish i would have saw this last night. Thanks for the workaround. Good to know for the future. Thanks!
deathtical
How do you do this? I looked all over the main site and the FAQ and couldn't find a way to buy a key. ThanksWoodstock wrote:buy a key that doesn't expire
The "buy" link is not the most obvious one on the site; I don't remember ever seeing a direct link to it on the site.
Within the program itself, Help->Purchase takes you to it... And the link is:
http://www.makemkv.com/buy/
