Feature Request: "Select All" & "Unselect All"
fotomax
#1 Post by fotomax » Tue Sep 23, 2014 6:13 pm
Especially when using MakeMKV with BluRay discs, there can be up to 50 different files that are automatically checked to be copied (by default). This can be a time consuming effort to un-select all but one of them if all you want to copy is one or two files.
Any way of adding a "select all" & "un-select all" feature?
Thanks for this awesome program!!
Re: Feature Request: "Select All" & "Unselect All"
#2 Post by Woodstock » Tue Sep 23, 2014 10:20 pm
What is the Mac equivalent of the Windows "Right-Click" context menu?
That is where you will in "select all/deselect all".... already implemented.
fotomax
#3 Post by fotomax » Tue Sep 23, 2014 10:50 pm
OK, I feel pretty stupid at this point. I shoulda known. Thanks for the help!
DVDave
#4 Post by DVDave » Sun Nov 30, 2014 7:57 am
One feature I would like to see is the ability to uncheck all subtitles with a single click. It's extremely tedious to go through each title and uncheck every language subtitle manually. Other BD ripping software have that functionality, I don't understand why MakeMKV makes it so difficult.
ndjamena
#5 Post by ndjamena » Sun Nov 30, 2014 8:33 am
That's what the default selection is for.
