Feature Request: "Select All" & "Unselect All"
fotomax
Post by fotomax »
Especially when using MakeMKV with BluRay discs, there can be up to 50 different files that are automatically checked to be copied (by default). This can be a time consuming effort to un-select all but one of them if all you want to copy is one or two files.
Any way of adding a "select all" & "un-select all" feature?
Thanks for this awesome program!!
Re: Feature Request: "Select All" & "Unselect All"
What is the Mac equivalent of the Windows "Right-Click" context menu?
That is where you will in "select all/deselect all".... already implemented.
fotomax
Post by fotomax »
OK, I feel pretty stupid at this point. I shoulda known. Thanks for the help!
DVDave
Post by DVDave »
One feature I would like to see is the ability to uncheck all subtitles with a single click. It's extremely tedious to go through each title and uncheck every language subtitle manually. Other BD ripping software have that functionality, I don't understand why MakeMKV makes it so difficult.
ndjamena
Post by ndjamena »
That's what the default selection is for.
