Agents of S.H.I.E.L.D. S1 D1 Error: Failed to Open Disc
byrddogg77
#1 Post by byrddogg77 » Fri Sep 19, 2014 9:40 pm
MakeMKV v1.8.13 win(x64-release) started
Title #2 has length of 18 seconds which is less than minimum title length of 7200 seconds and was therefore skipped
Title #5 has length of 2642 seconds which is less than minimum title length of 7200 seconds and was therefore skipped
Title #6 has length of 2486 seconds which is less than minimum title length of 7200 seconds and was therefore skipped
Title #7 has length of 2584 seconds which is less than minimum title length of 7200 seconds and was therefore skipped
Title #8 has length of 2544 seconds which is less than minimum title length of 7200 seconds and was therefore skipped
Title #9 has length of 2540 seconds which is less than minimum title length of 7200 seconds and was therefore skipped
Title #14 has length of 5 seconds which is less than minimum title length of 7200 seconds and was therefore skipped
Title #29 has length of 7 seconds which is less than minimum title length of 7200 seconds and was therefore skipped
Title #30 has length of 152 seconds which is less than minimum title length of 7200 seconds and was therefore skipped
Title #31 has length of 91 seconds which is less than minimum title length of 7200 seconds and was therefore skipped
ndjamena
Re: Agents of S.H.I.E.L.D. S1 D1 Error: Failed to Open Disc
#2 Post by ndjamena » Sat Sep 20, 2014 1:12 am
You really ought to use 1200 as a minimum title length if you plan on ripping TV Shows as well as movies. 7200 seconds is 2 hours - I'm pretty sure most movies aren't even that long.
byrddogg77
#3 Post by byrddogg77 » Sat Sep 20, 2014 12:15 pm
Thanks that seemed to help.
Should I be concerned about End were skipped due to cell commands (structure protection?)?
Title #2 has length of 18 seconds which is less than minimum title length of 1100 seconds and was therefore skipped
Cells 7-end were skipped due to cell commands (structure protection?)
Title #5 was added (6 cell(s), 0:43:59)
Title #6 was added (6 cell(s), 0:41:24)
Title #7 was added (6 cell(s), 0:43:02)
Title #8 was added (6 cell(s), 0:42:21)
Title #9 was added (6 cell(s), 0:42:17)
Title #14 has length of 5 seconds which is less than minimum title length of 1100 seconds and was therefore skipped
Title #29 has length of 7 seconds which is less than minimum title length of 1100 seconds and was therefore skipped
Title #30 has length of 152 seconds which is less than minimum title length of 1100 seconds and was therefore skipped
Title #31 has length of 91 seconds which is less than minimum title length of 1100 seconds and was therefore skipped
#4 Post by Woodstock » Sun Sep 21, 2014 2:06 am
SOMETIMES things that are skipped in this manner are important - and MakeMKV has to have SVQ files for some disks to discover when those times are. But, generally speaking, it should be fine.
