you cant alternate , they are fixedTo do it you simply must alternate even and odd fields for each eye yet still maintain 60fps. Well, with 240hz, you have the speed you need.
for example even numbered lines always go to the left eye, odd numbered lines always go to the right eye (or vice versa, it makes no difference)
there is no way to swap that
