Fantastic Four (4 Widescreen) L-EC UNCORRECTABLE ERROR
K0HAX
#1 Post by K0HAX » Wed Sep 17, 2014 1:25 am
I'm getting the following error for this disk. Replace ~ with the user's home directory I censored it.
Saving 1 titles into directory ~/BDrip/Fantastic Four
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '3572629504'
Failed to save title 0 to file ~/BDrip/Fantastic Four/title00.mkv
0 titles saved, 1 failed
Here is the version I'm using, as well as the top part of the log, I have not installed any previous versions on this computer.
MakeMKV v1.8.13 linux(x64-release) started
Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
File 00000.mpls was added as title #0
Title #00001.mpls has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00019.mpls was added as title #1
File 00028.mpls was added as title #2
File 00013.m2ts was added as title #3
Title #00014.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00021.m2ts was added as title #4
File 00022.m2ts was added as title #5
File 00023.m2ts was added as title #6
Title #00024.m2ts has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Re: Fantastic Four (4 Widescreen) L-EC UNCORRECTABLE ERROR
#2 Post by Woodstock » Wed Sep 17, 2014 1:30 am
Your drive told the operating system it can't read the disk in that spot. The operating system told MakeMKV, and MakeMKV told you.
First step when this happens is to try cleaning the disk. I like to clean them with spray-type furniture wax (I use Pledge), because it will also fill in a lot of minor scratches that are hard to see, unless you're a laser trying to read itty bitty little bumps in a substrate.
If the disk is new, you have the option of returning it for replacement; sometimes disks are bad from the factory, or damaged in transit.
aesculapius
#3 Post by aesculapius » Thu Sep 18, 2014 6:26 am
i have the same problem with this BLU RAY "THE LONE RANGER" movie:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00896.m2ts' at offset '0'
Backup failed
what should i do? i already cleaned the BR disc using PLEDGE. still giving me this error
#4 Post by Woodstock » Fri Sep 19, 2014 12:42 pm
A clean, unscratched disk can still have manufacturing flaws, and it is possible that the drive itself is dirty.
If you "Open" the disk instead of using backup, can you save the files as MKV files? Sometimes, the file that fails a backup is NOT one of the main title files, but backup doesn't know that... so the backup fails, even when you files you WANT are readable.
