makemkv: cannot connect to X server
remuxer
Post by remuxer » Fri Sep 12, 2014 9:51 am
i installed makemkv on Debian 7, if i type makemkv in the command line, I get this error:
Where is the problem?
Re: makemkv: cannot connect to X server
Post by Woodstock » Fri Sep 12, 2014 9:25 pm
Do you have X running? If not, there is no X server to connect to, so the graphic interface can't run.
The console version has a different file name.
l33tlinuxh4x0r
Post by l33tlinuxh4x0r » Fri Sep 12, 2014 10:02 pm
also are you trying to run it as root if so try using sux instead of su or sudo. Some distros only allow you to launch X applications as root using sux in terminal when logged in as another user.
