bluray "Source Code" will not play on linux
l33tlinuxh4x0r
Post by l33tlinuxh4x0r »
I have the bluray "Source Code". It works fine in windows but on the same computer fails to play in linux. I get the following error code when using VLC. Also the rest of my blurays play fine in both windows and linux.
vlc bluray:///dev/sr0
VLC media player 2.1.4 Rincewind (revision 2.1.4-0-g2a072be)
[0x183d1f8] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[0x1910038] qt4 interface error: Unable to load extensions module
index_parse.c:191: indx_parse(): error opening /run/media/user/SOURCE_CODE/BDMV/index.bdmv
index_parse.c:191: indx_parse(): error opening /run/media/user/SOURCE_CODE/BDMV/BACKUP/index.bdmv
[0x7f9de80009b8] main input error: open of `bluray:///dev/sr0' failed
