The Place Beyond the Pines
idaGaNnHUL
Post by idaGaNnHUL »
MakeMKV v1.8.13 darwin(x86-release) started
Optical drive "BD-RE TSSTcorp BDDVDW SE-506AB TS01d" opened in OS access mode.
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:462787469a0e5a90:TSSTcorp BDDVDW SE-506AB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..008D4D21215E967156C5F08DB68D44B4AA2 to device 'IoKit:IOBDServices:462787469a0e5a90:TSSTcorp BDDVDW SE-506AB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B0F63AD54B3AB6FC881E5917B4EFB4FA88 to device 'IoKit:IOBDServices:462787469a0e5a90:TSSTcorp BDDVDW SE-506AB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00F024EDF4A3D9038073CADED4EA61EED41 to device 'IoKit:IOBDServices:462787469a0e5a90:TSSTcorp BDDVDW SE-506AB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00D7659BA9A531B94936555EDF93E8C776B to device 'IoKit:IOBDServices:462787469a0e5a90:TSSTcorp BDDVDW SE-506AB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00DB74AEFAE6BC65B9522A3B280DB5CFBC2 to device 'IoKit:IOBDServices:462787469a0e5a90:TSSTcorp BDDVDW SE-506AB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..06F04953C6CDD6C05C433E3BE21B95AF3EA to device 'IoKit:IOBDServices:462787469a0e5a90:TSSTcorp BDDVDW SE-506AB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:462787469a0e5a90:TSSTcorp BDDVDW SE-506AB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0F002487DAF210A9107825C8E439820C9FF to device 'IoKit:IOBDServices:462787469a0e5a90:TSSTcorp BDDVDW SE-506AB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0A7E6F52EA5B733DCF74D47059CAF5A62F5 to device 'IoKit:IOBDServices:462787469a0e5a90:TSSTcorp BDDVDW SE-506AB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..035EAA6D1672246548FA9D7A7AB5A513572 to device 'IoKit:IOBDServices:462787469a0e5a90:TSSTcorp BDDVDW SE-506AB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..050B9AE3AC817C46A5FEC2B5CA9E0819373 to device 'IoKit:IOBDServices:462787469a0e5a90:TSSTcorp BDDVDW SE-506AB TS01'
Highest AACS version is v44 , MKB saved as MKB_v44_CATCHING_FIRE.tgz
Re: The Place Beyond the Pines
Key to issue:
Your drive cannot read part of the disk. That cascades to other errors, because vital pieces of data aren't available.
