Hello everyone! I'm having an issue. I'm trying to create a digital backup of the movie Frozen as we're going on a trip and I want to put it on my iPad for our son so he has access to watch it.
Here's the issue I'm running into. MakeMKV opens fine and it brings up the 3 titles but no matter which title I select, when I click on MakeMKV the conversion fails. I've tried unselecting all subtitles and just using the audio but it still fails.
Below is the error output that is getting generated. If anyone can offer assistance I'd greatly appreciate it. We leave tomorrow and I would really like to get this done.
Thank you kindly!
Please Help, trouble copying the movie Frozen
RarefiedAir03
RarefiedAir03
Re: Please Help, trouble copying the movie Frozen
Saving 1 titles into directory /Users/Admin/Desktop
DEBUG: Code 0 at y3tqOy<$kUH9m_Zb]Wpj:29394574
The source file '/BDMV/STREAM/00883.m2ts' is corrupt or invalid at offset 6254161920, attempting to work around
The source file '/BDMV/STREAM/00883.m2ts' is corrupt or invalid at offset 6254168064, attempting to work around
The source file '/BDMV/STREAM/00883.m2ts' is corrupt or invalid at offset 6254174208, attempting to work around
The source file '/BDMV/STREAM/00883.m2ts' is corrupt or invalid at offset 6254180352, attempting to work around
The source file '/BDMV/STREAM/00883.m2ts' is corrupt or invalid at offset 6254186496, attempting to work around
The source file '/BDMV/STREAM/00883.m2ts' is corrupt or invalid at offset 6254192640, attempting to work around
The source file '/BDMV/STREAM/00883.m2ts' is corrupt or invalid at offset 6254198784, attempting to work around
The source file '/BDMV/STREAM/00883.m2ts' is corrupt or invalid at offset 6254204928, attempting to work around
The source file '/BDMV/STREAM/00883.m2ts' is corrupt or invalid at offset 6254211072, attempting to work around
The source file '/BDMV/STREAM/00883.m2ts' is corrupt or invalid at offset 6254217216, attempting to work around
The source file '/BDMV/STREAM/00883.m2ts' is corrupt or invalid at offset 6254223360, attempting to work around
The source file '/BDMV/STREAM/00883.m2ts' is corrupt or invalid at offset 6254229504, attempting to work around
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00883.m2ts' at offset '6254622720'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00883.m2ts' at offset '6254622720'
DEBUG: Code 0 at KN{j!!TBx^4vdDt=N~>?:121263038
DEBUG: Code 0 at y3tqOy<$kUH9m_Zb]Wpj:121261888
DEBUG: Code 0 at KN{j!!TBx^4vdDt=N~>?:213130559
DEBUG: Code 3054015 at KN{j!!TBx^4vdDt=N~>?:29393286
DEBUG: Code 0 at w+3nox'_EICVV'\2,B8JH:213135090
Failed to save title 2 to file /Users/Admin/Desktop/Frozen_t02.mkv
0 titles saved, 1 failed
By not including the start of the log, I have to ask, "What version of MakeMKV are you running?" 1.8.13 is current, 1.8.12 has problems with some disks due to a bug. What was logged in the scan phase can be important, too.
However, this looks like a problem with the disk itself. MakeMKV found several areas where the data coming from the drive was not what was expected, and tried a variety of work-arounds to try to make sense of it. Since the areas are close together, it is likely to be a scratch or finger print on the surface.
Have you tried cleaning the disk?
RarefiedAir03
Thanks for the response. yes, my first attempt 2 days ago I was using version 1.8.12 and I was getting the error so yesterday I upgraded to 1.8.13 and again tried all 3 titles, all 3 titles come up with that error.Woodstock wrote:By not including the start of the log, I have to ask, "What version of MakeMKV are you running?" 1.8.13 is current, 1.8.12 has problems with some disks due to a bug. What was logged in the scan phase can be important, too.
After my initial post I thought it could be something with the disk so I inspected it and gave it a wipe down, the disc is in pristine condition, no scratches or anything. I tried another attempt after wiping the disc down and yet again, it failed after about 5mins into the conversion.
I'm really stumped with this one.
We will have to wait for Mike to decode what the debugging messages are saying, unfortunately. Others have successfully ripped Frozen (including the 3D version), so it might be a combination of this disk and your drive.
Mike may ask you to follow the testdump procedure found here: http://www.makemkv.com/onlinehelp/testdump.html
Myself, when I have suspect disk, I do the cleaning with Pledge furniture polish, because the wax will smooth out scratches you don't normally see.
