Wrong title numbering ripping BRs
mkvmaker
Post by mkvmaker »
I just ripped the Breaking Bad BR Season 4 Disc 3.
The correct order of the shows on this disc would be :
File 00809.mpls
File 00810.mpls
File 00811.mpls
File 00812.mpls
but makemkv uses another order:
MakeMKV v1.8.12 win(x64-release) started
Title #00350.mpls has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00002.mpls was added as title #0
Title #00262.mpls has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00810.mpls was added as title #1
Title #00099.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00811.mpls was added as title #2
File 00812.mpls was added as title #3
File 00809.mpls was added as title #4
Title #00003.mpls has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00603.mpls was added as title #5
Title #00494.mpls has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00471.mpls was added as title #6
Could you add a smarter option for renumbering/renaming titles or just leave the original names (filexyz instead of renumbering)?
I generally would have a possibility tp make some preselections in the settings like:
-forced subs only
-german subs only
-german audio
What do you think?
Would be a very cool feature, which DVDfab has but isn't working there (forced subs not complete).
Kind regards
mkvmaker
Re: Wrong title numbering ripping BRs
Mike has said that MakeMKV assigns title numbers to the files in the order they're found on the disk, rather than sorting by file name. While it is normal that they'd be placed in file name order, there is no requirement for that, so some BD authors do not bother. One publisher I regularly buy disks from ALWAYS puts them on in reverse file name order.... except when they don't.... so every BD has to be checked when ripping, to get the episodes in the right order.
