Need help with error log pls
Noddy
Post by Noddy »
Hi I wonder if someone could please help me getting the program to work with my set up.
I’m on my second Blu-ray drive and still no luck. I'm using an LG CH08LS10 (which I know others are using successfully) connected to an iMac running 10.6.2, makemkv can see the drive and correctly identifilys the name of any disc I put it, but that’s as far as I get. The name of the disc in the info window is the only information that I get and I can't open/get the video source info. I have installed and uninstalled the program, restarted and I'm now stuck.
I would be very grateful of any help and I have attached my log below.
Thanks in advance
Debug log started at Wed Mar 3 05:20:37 2010 , written by MakeMKV v1.4.12 beta darwin(x86-release)
001005:0000 MakeMKV v1.4.12 beta darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users//MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at c8=GYK2UOqP:d5AyWRC8_&Ra=Hn:121265039
001003:0020 DEBUG: Code 268435459 at c8=GYK2UOqP:d5AyWRC8_&Ra=Hn:213134975
001003:0020 DEBUG: Code 2281701379 at HTq04a@0Z8\7/Xy1:29396322
