AACS V4 Protection - Can't MKV no matter my DVD.
theravyn211
Post by theravyn211 »
I have quite an extensive blu-ray collection and it appears each movie with the follow protection fails.
AACS V4
I will get the following type message at the bottom.
Saving 1 titles into directory F:/Video/BST1NND1_BADDERSANTA
DEBUG: Code 0 at 6vk!rIT96JneaY~Pv B~:121268535
DEBUG: Code 0 at <G-=}6Afd)?q>KJ:121264717
DEBUG: Code 65536 at EL"2b>cl6&YX?wI"6I:121264280
DEBUG: Code 0 at EL"2b>cl6&YX?wI"6I:213134469
DEBUG: Code 0 at EL"2b>cl6&YX?wI"6I:121267914
DEBUG: Code 0 at EL"2b>cl6&YX?wI"6I:213136792
Failed to save title 0 to file F:/Video/BST1NND1_BADDERSANTA/title00.mkv
0 titles saved, 1 failed
What information do I need to provide to help with this problem?
Re: AACS V4 Protection - Can't MKV no matter my DVD.
If it were the actual AACS being a problem, you would see error codes about not being able to exchange keys.
Best step at this point is to follow the instructions in the FAQ listed in my signature, and submit the information to Mike via email.
trizzey22
Post by trizzey22 »
I received this message, and the protection is a little different AACS v47
Is there anything I should do differently? Is this something that y'all are working on? Thank you for all of the work y'all do, it's much appreciated! This is the message I got:
This disc uses newer version of AACS protection. Please let us know about it by visiting /a/?oenlMDtJuNO9wc...
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03EC29724B466E8F9BC12BACCF094E57DF7 to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..008AA2C6349FCAEDD0586E96558A603EB16 to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C4FE5B83F5DC2605986319D1527380DFBC to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0EA92832D06EB08531277D30AB3BE6E8774 to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0421CD33D72CEA33109EE8843F43BD044FD to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..05EAD0AB5CFDEA4F92CCA784EA17BB9840B to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..08335951DDCB46F2970BDC418D61CC22D4C to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..062256B8B10E58CEBC6043F595E0F6B5929 to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0F0B0221790E0618EC4512ADA005DECEACC to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0BDF8DD5527A6DE117ECA66550220ABC0CF to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0A9BD8124F6DC6DA345DAF8EE1C9D826C5C to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03E5B8866C7D6B77A489731C02A591CBF12 to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..07EBA8752C9F4FC5FA45DD818F1EC95961E to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0D8D8AF79C23AC218DAE4BC15D893D35F83 to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..054198F60C00D27A27A004D56E96933CB0B to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0054120D91334DFE80BFB633E39C4C50CE8 to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..08C963D5AD0960DD5FF43FDF34B90356932 to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0CA4CCE97BF3BB761F78B327734B151C1C5 to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00911784A540D702702E912EA5D160A9946 to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..040445559240877CD8ECF2A62D0F1CF2BD8 to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E0BA8CD63B47A01324465E60EC6201F52E to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0D683CE4E2754EE026881CF723239469B19 to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..047B28EAD7631FB0C183FD14ACCCE2D98A2 to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0AB0C9CBAEE94B6A26C7E3EAB270B87C6BA to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0FE2952B3A2F4D98CF00DC94D26E404A5A7 to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..090FEC5CB06FB117D83BC5558EA1D618788 to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..06BA3DB03FA17BF27551A4CF4F92FF3A7CA to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..081606DCCEF7484DFA879BD9AC2D1A10AE0 to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0A3AA0181B1411A098AFEDC1ADE62FA746F to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0725D59910A194E77DDF71F1689D51B2C1D to device 'IoKit:IOBDServices:f6a66e4ef673ada1:TSSTcorp BDDVDW SE-506BB TS00'
Highest AACS version is v47 , MKB saved as /Users/trey/.MakeMKV/MKB_v47_HELL_ON_WHEELS_S3D1.tgz
If you did not click on the link when it was up, please send the file created, /Users/trey/.MakeMKV/MKB_v47_HELL_ON_WHEELS_S3D1.tgz , to svq@makemkv.com so that Mike can update the program.
