BluRay with KDM folder and .bin files
download4004
Post by download4004 » Fri Jul 04, 2014 5:28 am
Hi, I have a bluray with a KDM folder containing .bin file. The regular .m2ts files are quite small while one of the .bin is quite large. If I remux the Bluray with makemkv I only get a few minutes long movie.
Any idea about how to proceed with such bluray (Japanese movie) ?
Thanks.
Re: BluRay with KDM folder and .bin files
Post by mike admin » Fri Jul 04, 2014 6:59 am
Can you play it on a regular blu-ray player? It appears to be an encrypted DCP master, not a regular blu-ray disc.
download4004
Post by download4004 » Fri Jul 04, 2014 7:22 am
I can play it with MPC-HC. Is there a way to change the structure so that I can use MAKEMKV to remux it ?
MAKEMKV works but only extracts a small file, as if the .bin are not decoded I guess.
It is a so called MGVC bluray (Japan)
Post by mike admin » Sat Jul 05, 2014 7:17 am
download4004 wrote:I can play it with MPC-HC.
What are you selecting? Just the folder, or one of the BIN files?
download4004 wrote:It is a so called MGVC bluray (Japan)
Please make a full disc backup of this disc with MakeMKV. Then, from this backup please copy CLIPINF and PLAYLIST folders with all files inside, compress, and send to support@makemkv.com . Please keep the backup on disc for further analysis.
download4004
Post by download4004 » Sat Jul 05, 2014 5:47 pm
Thanks for your reply
I will do and post it.
docchris
Post by docchris » Tue Sep 02, 2014 2:52 pm
Is there an update to this? i also have problems with a bluray structured with MGVC files
docchris
Post by docchris » Tue Sep 02, 2014 2:53 pm
Also, here is some more detail on these discs
http://www.avsforum.com/forum/114-hdtv- ... japan.html
medikoo
Post by medikoo » Thu Jan 26, 2023 12:49 pm
For those wondering, the link posted in previous post, most likely should lead here today: https://www.avsforum.com/threads/36-bit ... n.1486405/
