DTS Decoding Error
gekado
DTS Decoding Error
Post by gekado »
Ripping of a Bluray "Kristy" (german version) is working fine.
But the conversion of the audio track to flac crashes. (Conversion to aac crashes also.)
It seems to be a problem of decoding the DTS HD audio track.
Here is the Log:
Saving 1 titles into directory /Users/g/Movies using profile 'PCM->FLAC' from file '/Applications/MakeMKV.app/Contents/MacOS/../Resources/FLAC plus.mmcp.xml'
DEBUG: Code 8115 at o#s6'Jz>%uIsp!>\:121265522
DEBUG: Code 2 at osF)[Os|'G@D nudEQ:29400025
DEBUG: Code 0 at osF)[Os|'G@D nudEQ:213136792
Failed to save title 0 to file /Users/g/Movies/FSK16-KRISTY_-_Lauf_um_dein_Leben_t00.mkv
0 titles saved, 1 failed
ndjamena
Re: DTS Decoding Error
Post by ndjamena »
Have you ripped DTS-HD before? Do you have the Arcsoft DTS Decoder installed?
[[[ "PCM->FLAC" could this be my fault!!!! :o ]]]
ndjamena
Post by ndjamena »
I've been thinking:
1: If you're using 1.8.11 and that DTS-HD track is in fact DTS-HD LBR 1.8.11 could not rip most LBR tracks
2: Not knowing which DTS-HD variant you have, it's possible your DTS Decoder version is too old. Most versions you find on the net are 1.0.0.1, but apparently you need at least version 1.0.0.5 to be able to properly rip all forms of DTS-HD (or at least that's what I seem to recall MakeMKV telling me).
Post by mike admin »
1.8.13 should work.
gekado
Post by gekado »
Wow, you 're super fast.
But unfortunately converting to flac still does not work. :(
(log see below.)
By the way. The DTS HD stream seems to be intact. Leaving the dts hd stream as it is and playing it on vlc or a samsung player is working fine.
(I only need a conversion to flac for a new panasonic player ...)
Hope you can help! :P
MakeMKV v1.8.13 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/gerhard/MakeMKV_log.txt
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5690H 4AH5d" opened in OS access mode.
Optical drive "BD-ROM ASUS SBC-06D2X-U C202d" opened in OS access mode.
Saving 1 titles into directory /Users/gerhard/Movies using profile 'FLAC' from file '/Applications/MakeMKV.app/Contents/MacOS/../Resources/flac.mmcp.xml'
DEBUG: Code 8115 at +%)@QyZ|)$0UrK$y:121265522
DEBUG: Code 1 at o>]r>t Tg ij^/@"|":213136654
DEBUG: Code 0 at o>]r>t Tg ij^/@"|":29400669
Failed to save title 0 to file /Users/gerhard/Movies/FSK16-KRISTY_-_Lauf_um_dein_Leben_t00.mkv
gekado
Post by gekado »
I installed a dtsdecoderdll.dll some times ago. I don't know if it is from ARCSOFT or Windows, but it thought, this wouldn't matter. Right?
The Masked Onion
Post by The Masked Onion »
yes it could. make sure you are using the latest version from the Arcsoft TMT player.
gekado
Post by gekado »
Hmm. ARCSOFT is a Windows application. I 'm using OS X.
I thought, you only have to reference a DTSEncoder-DLL because of a license issue.
By the way: Reading a DTS audio track and converting it to flac works fine with most blurays.
Just converting the bluray mentioned above raises an error. So I 'm quite convinced that it is an error in MKV.
I still hope this is going to be fixed.
The Masked Onion
When i reported a few 7.1 DTS-HD to FLAC conversion problems in 1.8.11 and 1.8.12, MKVsupport replied stating that you need to be using at least dtsdecoderdll.dll version 1.1.0.9.
PM me if you want a copy of dtsdecoderdll.dll version 1.1.0.9.
