Posix error - Cannot allocate memory
Philip
#1 Post by Philip » Wed May 01, 2013 1:08 pm
I have just installed the version 1.8.1 on a xubuntu 13.04.
Everything goes fine except that, at the end of the process, makemkv fail to write the file (mutliple attempts with same result)
MakeMKV v1.8.1 linux(x64-release) started
File 00011.mpls was added as title #0
File 00001.mpls was added as title #1
Title #00001.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00085.m2ts was added as title #2
File 00086.m2ts was added as title #3
File 00087.m2ts was added as title #4
Saving 1 titles into directory /media/philippe/DATA/films/bluray
Error 'Posix error - Cannot allocate memory' occurred while reading '/BDMV/STREAM/00047.m2ts' at offset '2953183232'
Failed to save title 1 to file /media/philippe/DATA/films/bluray/title01.mkv
0 titles saved, 1 failed
DevNull
Re: Posix error - Cannot allocate memory
#2 Post by DevNull » Tue Aug 26, 2014 12:17 pm
I see the same sort of error (Blu-Ray):
MakeMKV v1.8.12 linux(x64-release) started
Backing up disc into folder "/tmp/THE_LORD_OF_THE_RINGS"
Evaluation version, 29 day(s) out of 30 remaining
Error 'Posix error - Cannot allocate memory' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '696385536'
Backup failed
UPDATE: Just added 16GB swap, same error, higher offset:
Error 'Posix error - Cannot allocate memory' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '1748631552'
Backup failed
UPDATE2: Just tried the DVD from LotR set, same error in multiple files:
Title #1 was added (40 cell(s), 2:12:50)
Title #2 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 was added (1 cell(s), 0:30:23)
Title #11 has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 was added (1 cell(s), 0:02:01)
Title #13 was added (1 cell(s), 0:02:11)
Title #14 was added (1 cell(s), 0:02:05)
Title #15 has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #16 was added (5 cell(s), 0:03:41)
Region setting of drive PIONEER:BD-RW BDR-209D does not match the region of currently inserted disc, trying to work around...
Subtitle stream #3 is identical to stream #2 and was skipped
Subtitle stream #4 is identical to stream #2 and was skipped
Subtitle stream #5 is identical to stream #2 and was skipped
Saving 6 titles into directory /home/dogfolk/rdocs/tmp/LotR
Error 'Posix error - Cannot allocate memory' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '407435264'
Failed to save title 0 to file /home/dogfolk/rdocs/tmp/LotR/title00.mkv
Error 'Posix error - Cannot allocate memory' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '0'
Failed to save title 1 to file /home/dogfolk/rdocs/tmp/LotR/title01.mkv
Error 'Posix error - Cannot allocate memory' occurred while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '0'
Failed to save title 2 to file /home/dogfolk/rdocs/tmp/LotR/title02.mkv
Failed to save title 3 to file /home/dogfolk/rdocs/tmp/LotR/title03.mkv
Failed to save title 4 to file /home/dogfolk/rdocs/tmp/LotR/title04.mkv
Error 'Posix error - Cannot allocate memory' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '0'
Failed to save title 5 to file /home/dogfolk/rdocs/tmp/LotR/title05.mkv
0 titles saved, 6 failed
MakeMKV v1.8.12
Linux Mint 17 (Ubuntu 14.04)
Pioneer BDR-209DBK
quad core AMD A8-3820
8GB RAM
drive currently attached via USB
engineermdr
#3 Post by engineermdr » Sat Aug 30, 2014 3:27 pm
Also seeing this problem on Debian Jessie.
Evaluation version, evaluation period expired 12 day(s) ago
File 00801.mpls was added as title #0
Title #00007.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00009.mpls was added as title #1
File 00800.mpls was added as title #2
File 00053.mpls was added as title #3
File 00020.mpls was added as title #4
Title #00955.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00285.mpls was added as title #5
File 00002.m2ts was added as title #6
Title #00004.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01018.m2ts was added as title #7
Title #01035.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01036.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01037.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01038.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01039.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01040.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01041.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01042.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01043.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01044.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01045.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01046.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01047.m2ts has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01048.m2ts has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01049.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01050.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01051.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01052.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01053.m2ts was added as title #8
Title #01054.m2ts has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01055.m2ts has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01056.m2ts has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01057.m2ts was added as title #9
File 01058.m2ts was added as title #10
Title #01059.m2ts has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01060.m2ts was added as title #11
Title #01061.m2ts has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01062.m2ts has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01063.m2ts was added as title #12
File 01064.m2ts was added as title #13
File 01065.m2ts was added as title #14
Title #01066.m2ts has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01067.m2ts was added as title #15
File 01068.m2ts was added as title #16
File 01069.m2ts was added as title #17
File 01070.m2ts was added as title #18
File 01071.m2ts was added as title #19
File 01072.m2ts was added as title #20
File 01073.m2ts was added as title #21
File 01074.m2ts was added as title #22
File 01075.m2ts was added as title #23
File 01076.m2ts was added as title #24
File 01077.m2ts was added as title #25
File 01078.m2ts was added as title #26
Title #01079.m2ts has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01080.m2ts was added as title #27
File 01081.m2ts was added as title #28
File 01082.m2ts was added as title #29
Title #01083.m2ts has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01084.m2ts was added as title #30
File 01085.m2ts was added as title #31
File 01086.m2ts was added as title #32
File 01087.m2ts was added as title #33
File 01088.m2ts was added as title #34
File 01089.m2ts was added as title #35
File 01090.m2ts was added as title #36
File 01091.m2ts was added as title #37
File 01092.m2ts was added as title #38
Title #01093.m2ts has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01094.m2ts has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01109.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01033.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01034.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 2 titles into directory /pub/video/Game_Of_Thrones_Season_1_Disc_1
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '192020480'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '3584688128'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '1533411328'
Error 'Posix error - Cannot allocate memory' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '1533411328'
Failed to save title 0 to file /pub/video/Game_Of_Thrones_Season_1_Disc_1/Game_Of_Thrones_Season_1_Disc_1_t00.mkv
Error 'Posix error - Cannot allocate memory' occurred while reading '/BDMV/STREAM/01018.m2ts' at offset '0'
Failed to save title 2 to file /pub/video/Game_Of_Thrones_Season_1_Disc_1/Game_Of_Thrones_Season_1_Disc_1_t02.mkv
0 titles saved, 2 failed
#4 Post by Woodstock » Sat Aug 30, 2014 3:51 pm
On the IO page of the Preferences menu, the Read buffer size is probably set to "Auto". Try setting it to a fixed size.
Larger buffers usually mean faster ripping, but sometimes you can have issues with large buffers. One of my machines is set to 256MB, because that machine is always low on free memory.
DevNull
#5 Post by DevNull » Sat Aug 30, 2014 7:48 pm
Thanks for the tip.... but it did not work. I tried setting the buffer size down in steps, finally ending up at 64.... each run took longer because of the decreasing buffer size, but all still ended in the Posix memory allocation error.
I watched system resource usage with each iteration, and, even with the largest buffers, no more than 33% of physical memory and 0.1% of swap were in use.
The debug log from the last (size 64) run is below. Note the repeating DEBUG message at the end (I terminated the process... this seemed to repeat endlessly).
Debug log started at Sat Aug 30 19:31:54 2014 , written by MakeMKV v1.8.12 linux(x64-release)
Using 65664KB for read cache.
001005:0000 MakeMKV v1.8.12 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/dogfolk/MakeMKV_log.txt
005072:0000 Backing up disc into folder "/tmp/LotR/backup/THE_LORD_OF_THE_RINGS"
005050:0000 Evaluation version, 25 day(s) out of 30 remaining
DAFD=PAAAADAAAAEABDQkEEwEBAQ==
DCE=bAGAomBmGwwxnb6skg9+hLJHb1cNAMSbyt7XK9ll3jw1+b5L46us/bvqDmc7Piy+FBYOpKSWo0d3bqxxnp6NZ2kTF2vg/YxHHzlHY7Jn/Z+xgLbr/OfWaJqfiwdk/yvoK1D4mLcfISKuV6sptll+DLEJeW9mMC7ktw==
DCE=G5wSnQGkkEuunHVOvteXYj23+FxI513e7Ku+iQb95SR4kPIEdxzABc68B5WZIk3768pLmOGlXTqwN9GoYbp3i5E4+Nm35eTYoDsBupN6JFMguAA56Qaf63F3KEEzjm6TKE0wwUjAuravp2HZA63+kDImyx1pkQY/Rg==
001003:0020 DEBUG: Code 1073741829 at BucY\K38a>4lrVy~:29393953
001003:0020 DEBUG: Code 738333616 at 6Xh(r!zJhwje)U ,:213138333
002003:0000 Error 'Posix error - Cannot allocate memory' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '536870912'
001003:0020 DEBUG: Code 0 at ,g#PT_Fk6Rfem057:6q:121265890
001003:0020 DEBUG: Code 0 at p_"H2C W"A-FDD<J(g_d:121265108
005069:0080 Backup failed
005080:0204 Backup failed.
001003:0020 DEBUG: Code 1073741836 at 6AigV`g~xM\T\<,::213134699
Application exited at Sat Aug 30 19:39:02 2014
engineermdr
#6 Post by engineermdr » Sat Aug 30, 2014 11:43 pm
I solved my problems. I found various errors in /var/log/kern.log all related to the sata interface my optical drive is on. I swapped out the sata cable to that drive and the problems went away. So it was either the cable or a loose connection in my case.
DevNull
#7 Post by DevNull » Sun Aug 31, 2014 12:24 pm
Interesting....
Running MakeMKV while whatching kern.log, I, too, see I/O errors. I've got my BD drive attached via a SATA to USB(2) adapter at the moment, so I wonder if this may be the source of the problem.
When i have some time, I'll mount it internally and use the native SATA interface. We'll see......!
DevNull
#8 Post by DevNull » Mon Sep 01, 2014 12:42 pm
[SOLVED] Posix error - Cannot allocate memory
Thanks to engineermdr for the idea - I installed my Pioneer BD-RW BDR-209D Revision: 1.10 internally, directly on the SATA i/f .... I had been using it via a SATA-to-USB2 interface. It now works flawlessly (well, admittedly, a small sample of discs so far).
The "cannot allocate memory" seems to be a flyer since the root cause was I/O errors - revealed in kern.log.
