Anyway, I love this tool. Keep up the good work
Pirates Of The Caribbean 3 fails to dump on latest version
Ronin22222
Hey guys. Just a heads up that POTC 3 fails to dump on the latest version. I went back to an older verison and it dumped fine. I used 1.8.0 to both make sure I went back far enough for it to work, but not back so far that it would cause problems with it......hopefully
Warrzone
Re: Pirates Of The Caribbean 3 fails to dump on latest versi
If you read other posts in the forum, you will see that 1.8.12 instantly fails when ripping LPCM. I got instant fails with 1.8.12 without any explanation codes. I reinstalled 1.8.11, and now everything is working again. If it says your version is too old, try updating the registration key.
pbcsd
How do we "update the registration key"? Is there a common registration key number that can be used in the popup when using the free version?
pbcsd
nevermind ... found the key..
Warrzone
