Cruel Intentions
Freed Fish
Cruel Intentions
Post by Freed Fish » Fri Aug 29, 2014 12:16 pm
I picked-up Cruel Intentions yesterday and encountered an issue getting it to rip via MakeMKV. The log is below since it appears "the board attachment quota has been reached", let me know if any additional information is needed. Thank you in advance for your help - I love MakeMKV it has revamped my whole library.
Debug log started at Fri Aug 29 12:07:10 2014 , written by MakeMKV v1.8.12 win(x64-release)
001005:0000 MakeMKV v1.8.12 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\JKaras/MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQkEGQQCAQ==
DCE=wZj0PdwiDt5mxzAdWVw8gFdvmLPWglkvnUjZpDmgyR320pcdtnUlvQKxQYgQJTzT/1cdOmoVEEpEHAPcTKPmgwk+bRJtOZ8qhtUhhcEIINR+es4BhUEiJ1UB9jpkJvvPBRvvLqP5qr53r3+FOtbyITU7KoFHfnFEjg==
DISCID=1540489B690467D6E7B39177626360ABD196EC7E
003307:0000 File 00000.mpls was added as title #0
003025:0000 Title #00015.mpls has length of 53 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00023.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00024.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00025.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00026.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00027.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00028.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00029.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00030.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00031.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00032.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00033.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00034.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00035.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00036.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00037.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00038.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00039.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00040.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00041.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00042.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00043.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00044.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00045.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00054.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003307:0000 File 00012.mpls was added as title #1
003307:0000 File 00051.mpls was added as title #2
003025:0000 Title #00052.mpls has length of 448 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 109 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 224 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 145 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 48 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 392 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 141 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003307:0000 File 00008.m2ts was added as title #3
003025:0000 Title #00009.m2ts has length of 355 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 230 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 217 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 14 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 26 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00045.m2ts has length of 9 seconds which is less than minimum title length of 900 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory F:/Video/Raw Folder/Cruel Intentions
001003:0020 DEBUG: Code 0 at *c:^ua"8oqyZ?|bBR" a:121268535
001003:0020 DEBUG: Code 0 at xB%~)f6dza=6dL-:121264717
001003:0020 DEBUG: Code 131072 at 4FDMwI=?rw's[6<z9i:121264280
001003:0020 DEBUG: Code 0 at 4FDMwI=?rw's[6<z9i:213134469
001003:0020 DEBUG: Code 0 at 4FDMwI=?rw's[6<z9i:121267914
001003:0020 DEBUG: Code 0 at 4FDMwI=?rw's[6<z9i:213136792
005003:0000 Failed to save title 0 to file F:/Video/Raw Folder/Cruel Intentions/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Fri Aug 29 12:07:50 2014
Re: Cruel Intentions
Post by Woodstock » Fri Aug 29, 2014 2:25 pm
What audio tracks are there? If any of them are LPCM, 1.8.12 has a bug related to LPCM audio. See topics like this one:
http://makemkv.com/forum2/viewtopic.php?f=8&t=8221
ndjamena
Post by ndjamena » Fri Aug 29, 2014 9:19 pm
Woodstock wrote:What audio tracks are there? If any of them are LPCM, 1.8.12 has a bug related to LPCM audio. See topics like this one:
http://www.blu-ray.com/movies/Cruel-Int ... u-ray/423/
Audio
English: LPCM 5.1 (48kHz, 16-bit)
English: Dolby Digital 5.1 (448 kbps)
Freed Fish
Post by Freed Fish » Fri Aug 29, 2014 11:53 pm
Ah, thank you.
Warrzone
Post by Warrzone » Sat Aug 30, 2014 7:29 am
MakeMKV 1.8.12 has an LPCM bug http://www.makemkv.com/forum2/viewtopic.php?f=8&t=8202. You have to use 1.8.11 to rip any movies with LPCM until the new version comes out /download/old/.
