Video: video tracks are copied lossless from the original source.
Audio: audio is, depending on it's source, either compressed losslessly or copied over, lossy ones are copied, lossless formats are compressed with FLAC with the highest compression setting.
Subtitles: subtitles are losslessly compressed with ZLIB using it's highest compression setting.
FLAC compression options:
-compression_level can be between 1 and 12, 12 being the highest compression.
-lpc_coeff_precision can be between 1 and 15, 15 being the highest compression.
-lpc_passes can be between 1 and about 4 billion, after 8 it starts having worse compression. (tested from 1 to 33 passes, on a 24 bit 48khz sample file, I haven't tested any other bit/sample rate, but if there's demand I will.)
-lpc_type sets the algorithm to use, 3 has the highest compression.
-threads sets how many cpus to use for encoding, change 2 to how many cores your computer has.
<?xml version="1.0" encoding="utf-8"?>
<profile>
    <!-- profile name - Perfect -->
    <name lang="eng">PERFECT</name>
    <!-- Common MKV flags -->
    <mkvSettings
        ignoreForcedSubtitlesFlag="false"
        useISO639Type2T="false"
    <!-- Settings overridable in preferences -->
    <profileSettings
        app_DefaultSelectionString="-sel:all,-sel:(core|special|lossy),-sel:(rus|spa),+sel:(eng|und|nolang),+sel:mvcvideo,+sel:attachment,=100:all,-10:favlang"
    <!-- Output formats currently supported by MakeMKV -->
    <outputSettings name="copy" outputFormat="directCopy">
        <description lang="eng">Copy track 1:1</description>
    </outputSettings>
    <outputSettings name="FLAC" outputFormat="FLAC">
        <description lang="eng">Compress Audio with FLAC</description>
        <extraArgs>-threads 2 -compression_level 12 -lpc_coeff_precision 15 -lpc_passes 8 -lpc_type 3</extraArgs>
    </outputSettings>
    <outputSettings name="zlib" outputFormat="directCopy">
        <description lang="eng">Compress subtitles with ZLIB</description>
        <extraArgs>compression="zlib" compressionLevel="9"</extraArgs>
    </outputSettings>
    <!-- Default rule - copy as is -->
    <trackSettings input="default">
        <output outputSettingsName="copy"
                defaultSelection="$app_DefaultSelectionString,+sel:true"></output>
    </trackSettings>
    <trackSettings input="Mpeg1">
    </trackSettings>
    <trackSettings input="Mpeg2">
    </trackSettings>
    <trackSettings input="Mpeg4">
    </trackSettings>
    <trackSettings input="VC1">
    </trackSettings>
    <!-- Lossless Audio -->
    <trackSettings input="TRUEHD-stereo">
        <output outputSettingsName="FLAC"
            defaultSelection="$app_DefaultSelectionString"></output>
    </trackSettings>
    <trackSettings input="TRUEHD-multi">
    </trackSettings>
    <trackSettings input="MLP-stereo">
    </trackSettings>
    <trackSettings input="MLP-multi">
    </trackSettings>
    <trackSettings input="DTSHDMA-stereo">
    </trackSettings>
    <trackSettings input="DTSHDMA-multi">
    </trackSettings>
    <trackSettings input="FLAC-stereo">
    </trackSettings>
    <trackSettings input="FLAC-multi">
    </trackSettings>
    <trackSettings input="LPCM-stereo">
    </trackSettings>
    <trackSettings input="LPCM-multi">
    </trackSettings>
    <!-- Lossy Audio -->
    <trackSettings input="MP2">
    </trackSettings>
    <trackSettings input="MP3">
    </trackSettings>
    <trackSettings input="DTS-stereo">
    </trackSettings>
    <trackSettings input="DTS-multi">
    </trackSettings>
    <trackSettings input="DTSHD-core-multi">
        </output>
    </trackSettings>
    <trackSettings input="DTSHD-core-stereo">
        </output>
    </trackSettings>
    <trackSettings input="DTSHD-stereo">
    </trackSettings>
    <trackSettings input="DTSHD-multi">
    </trackSettings>
    <trackSettings input="DTSHDLBR-stereo">
    </trackSettings>
    <trackSettings input="DTSHDLBR-multi">
    </trackSettings>
    <trackSettings input="AC3-stereo">
    </trackSettings>
    <trackSettings input="AC3-multi">
    </trackSettings>
    <trackSettings input="EAC3-stereo">
    </trackSettings>
    <trackSettings input="EAC3-multi">
    </trackSettings>
    <!-- Compress subtitles with ZLIB -->
    <trackSettings input="PGS">
        <output outputSettingsName="zlib"
    </trackSettings>
    <trackSettings input="PGS-forced">
    </trackSettings>
    <trackSettings input="VOBSUB">
    </trackSettings>
    <trackSettings input="VOBSUB-forced">
    </trackSettings>
    <trackSettings input="VOBSUBHD">
    </trackSettings>
    <trackSettings input="VOBSUBHD-forced">
    </trackSettings>
</profile>Code: Select all
Changes 1:
Optimized flac compression, moved dtshd and dts express to the lossy section, because they're not lossless, dtshd core is now deselected by default, MVC (3D view of a 3D Blu-ray) is now selected by defaultCode: Select all
Changes 2:
removed selection settings from track settings so the selection rules will work correctly.
