List of DVD/BluRay that haven't worked
theheath
Re: List of DVD/BluRay that haven't worked
#136 Post by theheath » Mon Mar 01, 2010 10:28 pm
Batman Returns DVD
Saving 1 titles into directory E:/Movies/Batman Returns
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occured while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '3938736128'
Failed to save title 0 to file E:/Movies/Batman Returns/title00.mkv
0 titles saved, 1 failed
popejobs
#137 Post by popejobs » Mon Mar 01, 2010 10:30 pm
@theheath: protip, maybe truncate "Cell 13 was discarded (structure protection?)" and put (repeated 300 times) next to thel ine rather than crap all over the thread.
setarip_old
#138 Post by setarip_old » Tue Mar 02, 2010 12:46 am
@theheath
Those read errors may likely be indicative of a physically damaged or dirty disc...
xxxerxxxes
#139 Post by xxxerxxxes » Wed Mar 03, 2010 8:27 pm
Clear and Present Danger: Blu Ray Disk: US region.
Here is the dump-
MakeMKV v1.4.12 beta win(x86-release) started
Debug logging enabled, log will be saved as C:\Users\Phil/MakeMKV_log.txt
Evaluation version, 23 day(s) out of 30 remaining
DEBUG: Code 30 at H*pi?TA2{p'k,@RDjnn;Y:121264579
DEBUG: Code 28 at H*pi?TA2{p'k,@RDjnn;Y:121264579
File 00001.mpls was added as title #0
File 00003.mpls was added as title #1
File 00004.mpls was added as title #2
File 00000.m2ts was added as title #3
File 00004.m2ts was added as title #4
File 00005.m2ts was added as title #5
File 00006.m2ts was added as title #6
File 00007.m2ts was added as title #7
File 00008.m2ts was added as title #8
File 00009.m2ts was added as title #9
File 00010.m2ts was added as title #10
File 00011.m2ts was added as title #11
Title #00012.m2ts has length of 1 seconds which is less than minimum title length of 4 seconds and was therefore skipped
Title #00013.m2ts has length of 1 seconds which is less than minimum title length of 4 seconds and was therefore skipped
File 00014.m2ts was added as title #12
File 00015.m2ts was added as title #13
File 00016.m2ts was added as title #14
File 00044.m2ts was added as title #15
File 00045.m2ts was added as title #16
File 00046.m2ts was added as title #17
File 00047.m2ts was added as title #18
File 00048.m2ts was added as title #19
File 00049.m2ts was added as title #20
File 00050.m2ts was added as title #21
File 00051.m2ts was added as title #22
File 00052.m2ts was added as title #23
File 00053.m2ts was added as title #24
File 00054.m2ts was added as title #25
File 00055.m2ts was added as title #26
File 00056.m2ts was added as title #27
File 00057.m2ts was added as title #28
File 00058.m2ts was added as title #29
File 00059.m2ts was added as title #30
File 00060.m2ts was added as title #31
File 00061.m2ts was added as title #32
File 00062.m2ts was added as title #33
File 00063.m2ts was added as title #34
File 00064.m2ts was added as title #35
File 00065.m2ts was added as title #36
File 00066.m2ts was added as title #37
File 00067.m2ts was added as title #38
File 00068.m2ts was added as title #39
Title #00069.m2ts has length of 1 seconds which is less than minimum title length of 4 seconds and was therefore skipped
File 00070.m2ts was added as title #40
Title #00071.m2ts has length of 1 seconds which is less than minimum title length of 4 seconds and was therefore skipped
Operation sucessfully completed
Saving 1 titles into directory C:/Video/Clear_and_Present_Danger
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occured while reading '/BDMV/STREAM/00001.m2ts' at offset '15729094656'
DEBUG: Code 0 at ll*mF+ZiejE0(=h_:121268305
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occured while reading '/BDMV/STREAM/00001.m2ts' at offset '15734992896'
DEBUG: Code 100864261 at %YgZ3hY8v0GVmY=id|:213132445
DEBUG: Code 100864261 at %YgZ3hY8v0GVmY=id|:29393654
DEBUG: Code 0 at GE\ZaI*!Lq{a%t`Fo/t+:213130628
DEBUG: Code 0 at ~:PG|(NF5(OHuxzkHChR:213129823
DEBUG: Code 0 at GE\ZaI*!Lq{a%t`Fo/t+:213130513
DEBUG: Code 7683102 at GE\ZaI*!Lq{a%t`Fo/t+:213129639
Failed to save title 0 to file C:/Video/Clear_and_Present_Danger/title00.mkv
Also having problems with:
The Devil's Own and Patriot Games. Will post dumps as soon as I retry Makemkv on them again.... Thanks
setarip_old
#140 Post by setarip_old » Thu Mar 04, 2010 12:41 am
@xxxerxxxes
Hi!
dtblair
#141 Post by dtblair » Sat Mar 06, 2010 6:16 pm
Tried ripping LEON The Professional bluray. No errors but all sound streams result in pops and clicks (no audio). Changing from one audio stream to the next causes the mkv to freeze
#142 Post by mike admin » Mon Mar 08, 2010 8:36 am
dtblair wrote:Tried ripping LEON The Professional bluray. No errors but all sound streams result in pops and clicks (no audio). Changing from one audio stream to the next causes the mkv to freeze
What player do you use for playback?
#143 Post by mike admin » Mon Mar 08, 2010 8:39 am
xxxerxxxes wrote:Clear and Present Danger: Blu Ray Disk: US region.
Here is the dump-
Medium error is a result of scratched disc. Please try to increase "IO error retry count" in preferences and cross your fingers.
The first error looks like a problem in MakeMKV. Is this error printed instantly or in the middle of conversion? Can you please try to redo the disc but deselect all subtitles, and see if error would appear again?
dtblair
#144 Post by dtblair » Tue Mar 09, 2010 9:08 pm
I use Media Player Classic - Home
setarip_old
#145 Post by setarip_old » Wed Mar 10, 2010 12:19 am
@dtblair
Hi!
An obvious question perhaps but, do you get different/better results when you play your original BluRay disc on the same system - or does it exhibit the same behavior?
Mnemos
#146 Post by Mnemos » Wed Mar 10, 2010 7:34 am
Neither disc of the Blu-ray release of Gunslinger Girl Il Teatrino ( http://www.amazon.com/Gunslinger-Girl-T ... 549&sr=1-3 ) rips properly. Tracks that include stuff like the menus or the extras rip fine, but the episodes themselves don't. I'm using makemkv 1.5.0 in Linux. Going into Windows, using AnyDVD to rip the disc to disk, and then going back into Linux to use makemkv again gets the same result. So, it doesn't look like it's a DRM issue. Each of the episodes gives an error like this:
005003:0000 Failed to save title 5 to file /home/bdrips/Gunslinger_Girl_Il_Teatrino/title05.mkv
I'm attaching the log from makemkv from trying to rip the first disc.
#147 Post by mike admin » Wed Mar 10, 2010 9:10 am
Mnemos wrote:Neither disc of the Blu-ray release of Gunslinger Girl Il Teatrino ( http://www.amazon.com/Gunslinger-Girl-T ... 549&sr=1-3 ) rips properly. Tracks that include stuff like the menus or the extras rip fine, but the episodes themselves don't.
Thank you for reporting. Known problem, but the exact cause and time estimate for fix are unknown yet. I wish I had better answer.
djmasturbeat
#148 Post by djmasturbeat » Sun Mar 14, 2010 8:09 pm
Battle Angel Alita - R1 - NTSC DVD (1993) version released by ADV (an anime release).
setarip_old
#149 Post by setarip_old » Mon Mar 15, 2010 4:00 am
@djmasturbeat
Hi!
Would you be kind enough to at least give us a clue as to the nature of your problem with this DVD?
dadaniel
Sunshine (Danny Boyle)
#150 Post by dadaniel » Mon Mar 15, 2010 8:22 pm
AACS v4, BD+, mpeg4
This is my only Blu-Ray rip where playback ist stuttering. Only main movie is selected and there are no errors in MakeMKV log.
VLC Log:
main warning: late picture skipped (999 > -3565)
main warning: late picture skipped (4999 > -3673)
main warning: late picture skipped (2999 > -3673)
main warning: late picture skipped (8999 > -3504)
main warning: late picture skipped (3999 > -3128)
main warning: late picture skipped (2999 > -3128)
main warning: late picture skipped (11999 > -3346)
main warning: late picture skipped (-3001 > -3651)
main warning: late picture skipped (3999 > -3238)
main warning: late picture skipped (13999 > -2928)
main warning: late picture skipped (14999 > -2928)
main warning: late picture skipped (10999 > -4196)
main warning: late picture skipped (20999 > -3897)
main warning: late picture skipped (999 > -2617)
main warning: late picture skipped (-1 > -2712)
main warning: late picture skipped (4999 > -3034)
main warning: late picture skipped (27999 > -3025)
main warning: late picture skipped (6999 > -3025)
main warning: late picture skipped (11999 > -3268)
main warning: late picture skipped (9999 > -3268)
main warning: late picture skipped (19999 > -1901)
main warning: late picture skipped (27999 > -2175)
main warning: late picture skipped (32999 > -2631)
main warning: late picture skipped (35999 > -2631)
main warning: late picture skipped (44999 > -3223)
