DTS-HD MA -> FLAC and keep both DTS-HD MA and TrueHD
I am a user of PLEX on a MAC Mini with OSX Mavericks so no HD audio but PLEX will convert TrueHD to PCM. Is there a profile that will convert DTS-HD MA to FLAC and also leave a copy of itself and not convert TrueHD but leave a copy. In this way I can use PLEX and PCM or my Dune HD and bitstream.
Re: DTS-HD MA -> FLAC and keep both DTS-HD MA and TrueHD
I believe this should be possible. You'd want something like this in your conversion profile:mancolh wrote:I am a user of PLEX on a MAC Mini with OSX Mavericks so no HD audio but PLEX will convert TrueHD to PCM. Is there a profile that will convert DTS-HD MA to FLAC and also leave a copy of itself and not convert TrueHD but leave a copy. In this way I can use PLEX and PCM or my Dune HD and bitstream.
<trackSettings input="DTSHDMA-multi">
<output outputSettingsName="flac-best"
defaultSelection="$app_DefaultSelectionString,+sel:true">
</output>
</trackSettings>
<trackSettings input="TRUEHD-multi">
<output outputSettingsName="copy">
</output>
</trackSettings>
I've also assumed your tracks are multi-channel (more than stereo). Otherwise you'll need a couple more trackSettings blocks in there for DTSHDMA-stereo and TRUEHD-stereo, but the idea is the same.
Hope this helps, happy ripping!
Bah, I shoud add that that same thread says that if more than one output type is specified for the same input, they are both put into the resulting MKV. So really you'd want something like this:mancolh wrote:I am a user of PLEX on a MAC Mini with OSX Mavericks so no HD audio but PLEX will convert TrueHD to PCM. Is there a profile that will convert DTS-HD MA to FLAC and also leave a copy of itself and not convert TrueHD but leave a copy. In this way I can use PLEX and PCM or my Dune HD and bitstream.
</trackSettings>
</trackSettings>
defaultSelection="$app_DefaultSelectionString,+sel:true>
</trackSettings>
(I hope... I'm still pretty new at this and can't test this myself right now. Someone more knowledgable please be gentle in correcting me
Thanks. I will give that a try and post back if it works.
Well, I gave it a try and unless I formatted wrong, it looks like we are only allowed one decoding selection per track. Maybe Mike can find a way to offer this feature, Here is the error:
MakeMKV v1.8.12 darwin(x86-release) started
Profile parsing error: duplicate track settings for input format '21'
Failed to load conversion profile from file '/Applications/MakeMKV.app/Contents/MacOS/../Resources/flac.mmcp.xml'
Optical drive "BD-ROM ASUS SBC-06D1S-U A301" opened in DASPI v1.4 mode
Got it.
I am new to xml editing but when I loaded the flac profile in notepad xml editor and added the extra outputs properly it worked. Thanks for the help
Glad to help.
Don't know why only one of my responses actually got posted here, oh well.
Anyway the post that didn't show linked to this, which can help for conversion profiles.
Happy ripping.
Happy ripping.
Now that I've tried it myself I see what I did wrong.mancolh wrote:Got it.
For anyone else's reference, in case they have a similar question: I was wrong to make a second trackSettings block. We really only need to make a second output tag inside that block. So mancolh's working conversion profile probably has something similar to this in it:
defaultSelection="$app_DefaultSelectionString">
</trackSettings>
</trackSettings>Re: DTS-HD MA -> FLAC and keep both DTS-HD MA and TrueHD
Hi etrask,
That is exactly how it looks and works great. I am now going through my collection and re ripping the .mkv files. It would be nice if I knew of a quick way (batching perhaps?) to reconvert all these files.
