The Patriot Extended Cut errors
wanderzz
Post by wanderzz »
When trying to copy this blu ray I get the following error. The hard disk has 80GB free and all other blu rays have worked. The blu ray will play as well.
MakeMKV v1.8.12 win(x64-release) started
Debug logging enabled, log will be saved as C:\directory/MakeMKV_log.txt
Evaluation version, 28 day(s) out of 30 remaining
Title #00000.mpls has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00112.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00113.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00114.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00117.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00118.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00119.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00124.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00125.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00126.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00128.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00129.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00130.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00142.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00144.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00139.mpls was added as title #0
Title #00000.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00074.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00077.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00086.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00087.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00088.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00111.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00112.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00113.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00114.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00117.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00118.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00119.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00124.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00125.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00126.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00128.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00129.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00130.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00132.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00133.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00134.m2ts was added as title #1
File 00135.m2ts was added as title #2
Title #00136.m2ts has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00137.m2ts was added as title #3
File 00138.m2ts was added as title #4
File 00139.m2ts was added as title #5
Title #00141.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00145.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00146.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 233 at Z5z8ilTsbS1/JfRz6y+khDNw:0
Saving 1 titles into directory D:/Video/LOGICAL_VOLUME_ID
DEBUG: Code 0 at *c:^ua"8oqyZ?|bBR" a:121268535
DEBUG: Code 0 at xB%~)f6dza=6dL-:121264717
DEBUG: Code 131072 at 4FDMwI=?rw's[6<z9i:121264280
DEBUG: Code 0 at 4FDMwI=?rw's[6<z9i:213134469
DEBUG: Code 0 at 4FDMwI=?rw's[6<z9i:121267914
DEBUG: Code 0 at 4FDMwI=?rw's[6<z9i:213136792
Failed to save title 0 to file D:/Video/LOGICAL_VOLMUE_ID/title00.mkv
0 titles saved, 1 failed
Warrzone
Re: The Patriot Extended Cut errors
Post by Warrzone »
If you read other posts in the forum, you will see that 1.8.12 instantly fails when ripping LPCM. I got instant fails with 1.8.12 without any explanation codes. I reinstalled 1.8.11, and now everything is working again. If it says your version is too old, try updating the registration key.
