Checking and unchecking the right boxes under "type"
olot007
#1 Post by olot007 » Thu Aug 21, 2014 5:04 am
After scanning a disc and you figure out which "title" you are going to rip, do you just have to un-check the remaining "title" boxes or do you also have to drill down and un-check the sub-items listed under that title as well?
thanks.
Re: Checking and unchecking the right boxes under "type"
#2 Post by Woodstock » Thu Aug 21, 2014 2:11 pm
Unchecking the title means nothing from that title will be ripped. You only have to worry about the tracks within titles you select to rip.
olot007
#3 Post by olot007 » Thu Aug 21, 2014 3:24 pm
thanks.
I figured that's the way it is but better to be safe than sorry... Many dvd's ahead of me.
