Anyway, I love this tool. Keep up the good work
Pirates Of The Caribbean 3 fails to dump on latest version
Ronin22222
Hey guys. Just a heads up that POTC 3 fails to dump on the latest version. I went back to an older verison and it dumped fine. I used 1.8.0 to both make sure I went back far enough for it to work, but not back so far that it would cause problems with it......hopefully
Re: Pirates Of The Caribbean 3 fails to dump on latest versi
If you read other posts in the forum, you will see that 1.8.12 instantly fails when ripping LPCM. I got instant fails with 1.8.12 without any explanation codes. I reinstalled 1.8.11, and now everything is working again. If it says your version is too old, try updating the registration key.
How do we "update the registration key"? Is there a common registration key number that can be used in the popup when using the free version?
nevermind ... found the key..
