Checking and unchecking the right boxes under "type"
olot007
Post by olot007 »
After scanning a disc and you figure out which "title" you are going to rip, do you just have to un-check the remaining "title" boxes or do you also have to drill down and un-check the sub-items listed under that title as well?
thanks.
Re: Checking and unchecking the right boxes under "type"
Unchecking the title means nothing from that title will be ripped. You only have to worry about the tracks within titles you select to rip.
olot007
Post by olot007 »
thanks.
I figured that's the way it is but better to be safe than sorry... Many dvd's ahead of me.
