Unable to rip "stream extension" from DTS Master Audio
duderino201
Post by duderino201 » Tue Aug 19, 2014 5:41 am
Hello everyone, first time poster here.
I'm trying to rip DTS Master Audio 7.1 from a Rio 2 Blu-ray.
When I select the 7.1 audio track from the disc (Shown as DTS-HD MA Surround 7.1 English in makeMKV) I get DTS 7.1 in the MKV file, but I don't seem to get the master audio or stream extension portion when checking with media info and power DVD.
Maybe it's working fine and I really am getting the full DTS-MA stream in the MKV, but I want to be sure and the only two tools I have to verify my rips are showing differences when I load up the m2ts file and the mkv file to compare.
Note: I've configured dtsdecoderdll.dll as shown on the makemkv website. (/dtshd/)
Here are some screen shots showing the difference in both powerDVD and in MediaInfo, can anyone explain to me what's going on?
I am just starting to rip my Blu-ray collection and I want to get all my settings down just right so I don't have to go back and do it again later.
Thanks for any guidance anyone can provide.
MakeMKV Settings:
Playing Blu-ray in PowerDVD:
Playing MKV file in PowerDVD:
m2ts file in MediaInfo:
D : 4352 (0x1100)
Menu ID : 1 (0x1)
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Muxing mode : Stream extension
Codec ID : 134
Duration : 1h 32mn
Bit rate mode : Variable
Bit rate : Unknown / 1 509 Kbps
Channel(s) : 8 channels / 6 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
MKV file in MediaInfo:
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 1h 41mn
Bit depth : 24 bits
Title : Surround 7.1
Language : English
Default : Yes
Forced : No
Romansh
Re: Unable to rip "stream extension" from DTS Master Audio
Post by Romansh » Thu Aug 21, 2014 12:41 am
duderino201 wrote:MKV file in MediaInfo:
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 1h 41mn
Bit depth : 24 bits
Language : English
Default : Yes
Forced : No
