Superbad instantly fails
Gronnie
#1 Post by Gronnie » Sun Aug 17, 2014 3:46 pm
Tried ripping Superbad on 4 different LG UH12NS30 drives and each time it instantly fails. Never encountered this before. The discs looks absolutely pristine. Any ideas?
Saving 1 titles into directory D:/BD Rips/Superbad (1997)[TrueHD]
Failed to save title 0 to file D:/BD Rips/Superbad (1997)[TrueHD]/Superbad (1997)[TrueHD].mkv
0 titles saved, 1 failed
I have read retry count set to 25, so not sure how it can fail almost instantly.
Gronnie
Re: Superbad instantly fails
#2 Post by Gronnie » Mon Aug 18, 2014 6:16 pm
Here's a log of an attempt:
Debug log started at Mon Aug 18 18:13:29 2014 , written by MakeMKV v1.8.12 win(x64-release)
001005:0000 MakeMKV v1.8.12 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Alex/MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQkEFgACAQ==
DCE=cIpxF2+PemZ+eJpBA90pJZEcZzaZRPk3xASfIpzgs4xY3ntEL/o5KQOprguYWkI/eIqqPjCvSGU0ICOqmVDFynQIjD+wtBKNvCglutil82W3pT3gwpNWQmjYqm1qaX/cxbO0CZ3d69VtqkL+JA+u0R50z+6FgrzjvA==
DCE=2UaSyYYey8YPsaJN5fytEeZhqBa+UnISO7R8JMT9NxNOK3pL56qznLp4B+WAFN3YKeJzryABqFRgIGTy2rIwpopRnSe8u8PW4Ej8UzxBuIWCR8Ed8G9uY/RiPdLBHI3ug/vIfgzPMBghTNXZx+7YwWmcB4c8NKz/8Q==
DISCID=E7CEF2FDBAC16037C7D854AB9501825183C2D3E8
003025:0000 Title #00222.mpls has length of 128 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003307:0000 File 00001.mpls was added as title #0
003025:0000 Title #00102.mpls has length of 60 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00099.mpls has length of 128 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00224.mpls has length of 574 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00200.mpls has length of 180 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00202.mpls has length of 126 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00203.mpls has length of 119 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00204.mpls has length of 67 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00205.mpls has length of 76 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00201.mpls has length of 47 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00206.mpls has length of 194 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 14 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 64 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 1 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 1 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00081.m2ts has length of 60 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00082.m2ts has length of 0 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00083.m2ts has length of 0 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00099.m2ts has length of 173 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00100.m2ts has length of 40 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00101.m2ts has length of 119 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00102.m2ts has length of 112 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00103.m2ts has length of 60 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00104.m2ts has length of 69 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00105.m2ts has length of 187 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00106.m2ts has length of 255 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00107.m2ts has length of 268 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00109.m2ts has length of 32 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00110.m2ts has length of 152 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00111.m2ts has length of 152 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00112.m2ts has length of 183 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00113.m2ts has length of 152 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00114.m2ts has length of 101 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00115.m2ts has length of 74 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00116.m2ts has length of 94 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00117.m2ts has length of 266 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00118.m2ts has length of 146 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00119.m2ts has length of 64 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00120.m2ts has length of 61 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00122.m2ts has length of 6 seconds which is less than minimum title length of 900 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory D:/BD Rips/Superbad (2007)
001003:0020 DEBUG: Code 0 at *c:^ua"8oqyZ?|bBR" a:121268535
001003:0020 DEBUG: Code 0 at xB%~)f6dza=6dL-:121264717
001003:0020 DEBUG: Code 196608 at 4FDMwI=?rw's[6<z9i:121264280
001003:0020 DEBUG: Code 0 at 4FDMwI=?rw's[6<z9i:213134469
001003:0020 DEBUG: Code 0 at 4FDMwI=?rw's[6<z9i:121267914
001003:0020 DEBUG: Code 0 at 4FDMwI=?rw's[6<z9i:213136792
005003:0000 Failed to save title 0 to file D:/BD Rips/Superbad (2007)/Superbad_t00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Mon Aug 18 18:14:47 2014
Gronnie
#3 Post by Gronnie » Wed Aug 20, 2014 9:18 am
Well, I figured out the problem. It's the LPCM audio track. As soon as I tried to rip it w/o it, everything went fine.
Thanks @Ravik
http://www.makemkv.com/forum2/viewtopic ... 209#p35051
Ravik wrote:It's the LPCM audio track. Had a similar problem ripping one of my own videos that had this on it. Ripped everything else just fine except for the main track0, which has a DD 5.1 track and an LPCM track. I've ripped LPCM in the past with no problem, so I took a quick look at the 1.8.12 change log and saw that some updates to the LPCM code was made in this release. When I unchecked the LPCM box, the video began ripping just fine afterwards.
Hope that helps.
Ravik
CarlEdman
#4 Post by CarlEdman » Fri Aug 29, 2014 11:19 pm
I had a similar error code with the Blu-Ray of 2001: A Space Odyssey:
DEBUG: Code 131072 at 4FDMwI=?rw's[6<z9i:121264280
Disabling the extraneous LPCM audio track fixed the problem. Thanks!
