MakeMKV is not compatible with Mac OS X beta 10.10 Yosemite
Old, outdated, resolved and locked topics end up here...
Moderator: mike admin
Post by mike admin » Tue Aug 05, 2014 10:17 am
Update - the underlying bug in OS X was fixed in Yosemite developer preview 4. MakeMKV is fully compatible with OS X 10.10 Yosemite
As of now, MakeMKV is not compatible with the latest version of OS X - 10.10 "Yosemite" . The reason is a quiet withdrawal of an API that is required for MakeMKV GUI communication with makemkvcon process. So, while console-only makemkvcon would function as expected, launching the GUI would produce "Application failed to initialize" error. The fix is unlikely to arrive before official OS X release, while OS X 10.10 is in beta.
Technical details:
In 10.10 Apple rewrote from scratch so-called launchd daemon and related libraries. As part of that, so-called "bootstrap" API is no longer working, specifically the NSMachBootstrapServer::registerPort (which uses a low-level undocumented bootstrap_register2 API) no longer functions. As part of launchd rewrite, Apple removed all debugging and logging facilities (really, the "log" option in launchctl is now deprecated). Also, no source code is provided for the new daemon before OS release.
So, presently, the API that is declared as non-deprecated no longer functions, there is no (documented) way to enable logging, no source code and no debugging resources whatsoever. As noted earlier, the fix is unlikely to arrive before official OS X release.
ChrisJ60
Re: MakeMKV is not compatible with Mac OS X beta 10.10 Yosem
Post by ChrisJ60 » Sun Aug 10, 2014 7:51 am
Thanks for this information; this is quite troubling. I rely heavily on MakeMKV but I also want to be able to upgrade to Yosemite pretty much at the time it is released. Of all the third party apps and extensions etc. that I use, currently (Yosemite DP 5) the only one that is not already working is MakeMKV :(.
As far as I can see from the documentation this class/method (NSMachBootstrapServer::registerPort) should still work under OS X 10.10. Have you logged a bug with Apple on this? If there is some bug in this area then it could affect other software as well.
seantnichols
Post by seantnichols » Thu Aug 14, 2014 12:34 am
ChrisJ60 wrote:...As far as I can see from the documentation this class/method (NSMachBootstrapServer::registerPort) should still work under OS X 10.10. Have you logged a bug with Apple on this? If there is some bug in this area then it could affect other software as well.
I've seen this sort of thing before from Apple, it isn't uncommon for something that is supposed to work, not to work until after the release. It's very possible it will be resolved with the GM.
One alternative, if you could call it that, would be to run MakeMKV in a 10.9 VM under Parallels/VMWare/VirtualBox. This would give you the best of both worlds until a true solution can be found. VM's generally run slower because they don't have 3D acceleration however you're just talking about disc IO so it shouldn't be limited. I am going to experiment with this myself as I am in your same boat.
chaos215bar2
Post by chaos215bar2 » Thu Aug 14, 2014 4:21 am
So, how do I enter a registration key for makemkvcon? (v1.8.11 is the current release.)
MakeMKV v1.8.11 darwin(x86-release) started
Profile parsing error: default profile missing, using builtin default
Optical drive "BD-RE MATSHITA BD-MLT UJ265 1.00d" opened in OS access mode.
This application version is too old.  Please download the latest version at http://www.makemkv.com/ or enter a registration key to continue using the current version.
Edit: For anyone else trying to figure this out, you can copy the MakeMKV folder from ~Library on your Mavericks install, and manually edit settings.conf to insert an updated key, if you need. It's probably also sufficient to create an empty settings.conf in that location and just add the single line:
app_Key = "[Your Key]"
TJLuoma
Post by TJLuoma » Tue Aug 19, 2014 11:39 pm
Just in case anyone else finds this thread via Google and then can't find the MakeMKV folder in ~/Library/ -- that's because it isn't there :-)
It's ~/.MakeMKV/
Which I knew, but forgot, and went a little nutty trying to find.
However, even after copying the ~/.MakeMKV/settings.conf file from my Mavericks Mac to my Yosemite Mac, I still get an error: "Application failed to initialize"
This is with version 1.8.12 of MakeMKV using the first version of the Yosemite public beta.
chaos215bar2
Post by chaos215bar2 » Wed Aug 20, 2014 2:14 am
TJLuoma wrote:Just in case anyone else finds this thread via Google and then can't find the MakeMKV folder in ~/Library/ -- that's because it isn't there :-) It's ~/.MakeMKV/
It must have moved at some point, so I assume both work. Mine was in ~/Library/MakeMKV.
TJLuoma wrote:However, even after copying the ~/.MakeMKV/settings.conf file from my Mavericks Mac to my Yosemite Mac, I still get an error: "Application failed to initialize
Yes, this procedure is just to get makemkvcon working if it's complaining about an out of date registration (since the MakeMKV app doesn't work on Yosemite). The problem with the MakeMKV app itself is completely different.
nil404
Post by nil404 » Thu Aug 21, 2014 8:35 pm
Just tried Beta 2 release and MKV failed at launch. Sent a bug report to Apple about it. Don't know if it will help any. Hope you get it working for final release.
DJRumpy
Post by DJRumpy » Sun Aug 24, 2014 1:01 pm
Is there documentation anywhere for the console version that does work? I glanced through the faq and help docs but didn't spot it. Even if I can get it working via command line, it's worth it.
nwoolls
Post by nwoolls » Sun Aug 24, 2014 9:51 pm
DJRumpy wrote:Is there documentation anywhere for the console version that does work? I glanced through the faq and help docs but didn't spot it. Even if I can get it working via command line, it's worth it.
http://www.makemkv.com/forum2/viewtopic ... 014#p34880
DJRumpy
Post by DJRumpy » Sun Aug 24, 2014 10:03 pm
Thanks and much appreciated. Exactly what I needed.
DJRumpy
Post by DJRumpy » Mon Aug 25, 2014 2:04 pm
I just get a generic failure reading disc. :/
It sees the correct drive. Indicates it's in direct disk mode and then errors.
DJRumpy
Post by DJRumpy » Mon Aug 25, 2014 5:52 pm
/Applications/MakeMKV.app/Contents/MacOS/makemkvcon info disc:1
MakeMKV v1.8.12 darwin(x86-release) started
Optical drive "BD-ROM Optiarc BD ROM BC-5500S 1.75d" opened in OS access mode.
Total 0 titles
nwoolls
Post by nwoolls » Tue Aug 26, 2014 9:02 pm
DJRumpy wrote:/Applications/MakeMKV.app/Contents/MacOS/makemkvcon info disc:1
Total 0 titles
Looks like you only have one drive, but you are specifying disc:1 which is the second drive (drives are 0 based). See the notes in my other post for details.
DJRumpy
Post by DJRumpy » Tue Aug 26, 2014 9:49 pm
No I have two drives. The internal DVD-Rom and my external BD-Rom.
nwoolls
Post by nwoolls » Wed Aug 27, 2014 7:36 pm
DJRumpy wrote:No I have two drives. The internal DVD-Rom and my external BD-Rom.
Hmm tough to say. When I run the command it shows both drives, even though I am scanning only the 2nd:
./makemkvcon info disc:1
MakeMKV v1.8.10 darwin(x86-release) started
Optical drive "DVD+R-DL HL-DT-ST DVD-RW GH61N PA03d" opened in OS access mode.
Optical drive "BD-RE HL-DT-ST BD-RE  BH14NS40 1.00d" opened in OS access mode.
The new version 1.8.12 is available for download at http://www.makemkv.com/download/
