Bluray rip fails halfway through on almost all discs
Tiedemate
Post by Tiedemate » Tue Aug 19, 2014 7:21 pm
I have a hard time ripping BluRays. I have an Amazon Lovefilm account and receive two discs a month, which I rip to my USB-Stick to watch since I don't have a Hardware BluRay-Player. DVDs work ok, but BluRays fail almost all the time after having ripped a couple of GB...
Makemkv says:
Saving 1 titles into directory /home/tiedemate/smb4k/WIRELESSSPACE/OpenShare/Movies/Sergio Leone/F?r Ein Paar Dollar Mehr
Error 'Scsi error - NOT READY:MEDIUM NOT PRESENT' occurred while reading '/BDMV/STREAM/00021.m2ts' at offset '1757544448'
Failed to save title 0 to file /home/tiedemate/smb4k/WIRELESSSPACE/OpenShare/Movies/Sergio Leone/F?r Ein Paar Dollar Mehr/F?r_ein_paar_Dollar_mehr_t00.mkv
0 titles saved, 1 failed
dmesg says:
[  131.230103] UDF-fs: INFO Mounting volume 'PAAR_DOLLAR_MEHR', timestamp 2013/02/07 16:25 (1078)
[ 1827.911522] type=1400 audit(1408469175.141:47): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=3088 comm="apparmor_parser"
[ 1827.911533] type=1400 audit(1408469175.141:48): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/sbin/cupsd" pid=3088 comm="apparmor_parser"
[ 1827.912114] type=1400 audit(1408469175.141:49): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/sbin/cupsd" pid=3088 comm="apparmor_parser"
[ 5358.446608] FS-Cache: Loaded
[ 5358.464905] FS-Cache: Netfs 'cifs' registered for caching
[ 5358.465015] Key type cifs.spnego registered
[ 5358.465029] Key type cifs.idmap registered
[ 6642.910298] CE: hpet increased min_delta_ns to 20115 nsec
[ 7788.538401] usb 1-4: reset high-speed USB device number 2 using ehci-pci
[ 7798.780482] usb 1-4: reset high-speed USB device number 2 using ehci-pci
[ 7815.021235] usb 1-4: reset high-speed USB device number 2 using ehci-pci
[ 7815.269183] usb 1-4: reset high-speed USB device number 2 using ehci-pci
[ 7815.407697] sr 6:0:0:0: [sr1] Device not ready
[ 7815.407711] sr 6:0:0:0: [sr1]
[ 7815.407716] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 7815.407721] sr 6:0:0:0: [sr1]
[ 7815.407725] Sense Key : Not Ready [current]
[ 7815.407732] sr 6:0:0:0: [sr1]
[ 7815.407739] Add. Sense: Medium not present
[ 7815.407744] sr 6:0:0:0: [sr1] CDB:
[ 7815.407747] Read(10): 28 00 00 4d 34 e0 00 00 3c 00
[ 7815.407765] end_request: I/O error, dev sr1, sector 20239232
[ 7815.410085] sr 6:0:0:0: [sr1] Device not ready
[ 7815.410096] sr 6:0:0:0: [sr1]
[ 7815.410100] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 7815.410104] sr 6:0:0:0: [sr1]
[ 7815.410107] Sense Key : Not Ready [current]
[ 7815.410114] sr 6:0:0:0: [sr1]
[ 7815.410120] Add. Sense: Medium not present
[ 7815.410124] sr 6:0:0:0: [sr1] CDB:
[ 7815.410127] Read(10): 28 00 00 4d 35 1c 00 00 3c 00
[ 7815.410143] end_request: I/O error, dev sr1, sector 20239472
[ 7815.412216] sr 6:0:0:0: [sr1] Device not ready
[ 7815.412227] sr 6:0:0:0: [sr1]
[ 7815.412231] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 7815.412235] sr 6:0:0:0: [sr1]
[ 7815.412239] Sense Key : Not Ready [current]
[ 7815.412245] sr 6:0:0:0: [sr1]
[ 7815.412251] Add. Sense: Medium not present
[ 7815.412256] sr 6:0:0:0: [sr1] CDB:
[ 7815.412259] Read(10): 28 00 00 4d 35 58 00 00 3c 00
[ 7815.412274] end_request: I/O error, dev sr1, sector 20239712
[ 7815.414554] sr 6:0:0:0: [sr1] Device not ready
[ 7815.414567] sr 6:0:0:0: [sr1]
[ 7815.414572] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 7815.414578] sr 6:0:0:0: [sr1]
[ 7815.414581] Sense Key : Not Ready [current]
[ 7815.414588] sr 6:0:0:0: [sr1]
[ 7815.414594] Add. Sense: Medium not present
[ 7815.414599] sr 6:0:0:0: [sr1] CDB:
[ 7815.414602] Read(10): 28 00 00 4d 35 94 00 00 0c 00
[ 7815.414619] end_request: I/O error, dev sr1, sector 20239952
[ 7879.534174] VFS: busy inodes on changed media or resized disk sr1
I can however successfully copy the entire encrypted disc to my USB-Stick using a file manager. The transfer rate will drop sometimes to extremely low levels, so the drives do have issues reading the discs, but finally the copy will succeed. If I know try to open the copied files, I get:
Opening files on harddrive at /media/tiedemate/Stickos
I have tested with two different drives on multiple discs, which only have very minor scratches.
What can I do?
Bj?rn
Re: Bluray rip fails halfway through on almost all discs
Post by Woodstock » Tue Aug 19, 2014 10:07 pm
Is this a bus-powered USB drive?
The error messages are very similar to those given by OS/X and Windows when MakeMKV starts spinning the disk fast enough that the power from the USB port cannot keep up with the drive's demands. The voltage drops, the drive goes off-line, and nasty messages appear in logs. Then the drive is back... because the power draw dropped back to what the port could supply.
Fixes include making sure that the drive is plugged into a POWERED hub, and, if the drive has a "two-head" cable, making sure both USB plugs are plugged in. Some times using a USB 3 port, with its higher current limit, works, so long there is nothing else on the USB bus.
Most programs are not capable of pulling video off a BD as fast as MakeMKV can. Bus-powered USB drives sometimes come with a power supply for use when the USB ports cannot supply enough power.
Tiedemate
Post by Tiedemate » Wed Aug 20, 2014 5:51 pm
I have taken the drive out of the external case and mounted it into a laptop, same result :(
SidebandSamurai
Post by SidebandSamurai » Sat Aug 23, 2014 5:53 am
Is it possible that the firmware of the BluRay player needs to be updated?
Tiedemate
Post by Tiedemate » Sat Aug 23, 2014 9:24 pm
If have searched for new firmware for both my drives, to no avail. However I have once again complained about the discs at Amazon and got replacements, and those I could rip successfully. Looks like all of the discs were defective, but I am a bit puzzled because no severe scratches were visible. Fingers crossed for the next ones...
