Version 1.8.12 Instantly Fails
Warrzone
#1 Post by Warrzone » Mon Aug 18, 2014 11:25 pm
I updated to version 1.8.12, and now when I click on the convert button, it instantly fails. I get no explanation code. I have tried a few different discs. I reinstalled version 1.8.11. Now everything is working again. I wanted to make someone aware of this.
Here's the link to download old MakeMKV versions: /download/old/.
Edit: It's only a problem ripping discs with LPCM audio as many other threads point out. I would just reinstall 1.8.11 unless a patch is released or until 1.8.13 comes out.
Gronnie
Re: Version 1.8.12 Instantly Fails
#2 Post by Gronnie » Tue Aug 19, 2014 3:27 am
I only had the problem with the one disc. I was successfully able to rip three other BD and a DVD that same session without issue.
DoofToo
#3 Post by DoofToo » Tue Aug 19, 2014 8:39 pm
I'm having this exact problem. I'm actually really happy to see this post as I was beginning to think it was just me. I haven't tried downgrading yet, but I've been meaning to give that a try. I just wasn't sure if it would even work as I'm seeing numerous posts saying that 1.8.11 is too old to run. Glad to hear that it worked for you.
#4 Post by Woodstock » Tue Aug 19, 2014 10:10 pm
Three posts saying "it doesn't work". Not one offering any information that might be helpful.
wsmeyer
#5 Post by wsmeyer » Wed Aug 20, 2014 12:30 am
Same here. Been using MakeMKV for a couple months without a problem. I upgraded to 1.8.12 and it just instantly fails now:
Saving 1 titles into directory F:/Movies
DEBUG: Code 0 at *c:^ua"8oqyZ?|bBR" a:121268535
DEBUG: Code 0 at xB%~)f6dza=6dL-:121264717
DEBUG: Code 65536 at 4FDMwI=?rw's[6<z9i:121264280
DEBUG: Code 0 at 4FDMwI=?rw's[6<z9i:213134469
DEBUG: Code 0 at 4FDMwI=?rw's[6<z9i:121267914
DEBUG: Code 0 at 4FDMwI=?rw's[6<z9i:213136792
Failed to save title 0 to file F:/Movies/title00.mkv
0 titles saved, 1 failed
Anywhere I can download 1.8.11 ??
Warrzone
#6 Post by Warrzone » Wed Aug 20, 2014 12:40 am
I searched too, and I found that MakeMKV actually has all the old versions on the website. Here is the list of the old versions: http://www.makemkv.com/download/old/.
Here is the direct download link for the Windows version of 1.8.11.exe: http://www.makemkv.com/download/old/Set ... 1.8.11.exe.
Anyone who is getting the error that it is too old just needs to register the key again.
#7 Post by mike admin » Fri Aug 22, 2014 10:22 am
wsmeyer wrote:Same here. Been using MakeMKV for a couple months without a problem. I upgraded to 1.8.12 and it just instantly fails now:
Does it work if you don't select audio tracks at all? Can you please indicate what specific audio track causes the issue?
ndjamena
#8 Post by ndjamena » Fri Aug 22, 2014 12:37 pm
The stereo PCM tracks in Season 4 of Merlin still rip fine. It has both a 24 bit sound track and a 16 bit commentary track. The pure 24 bit audio in the first Iron Man AA BD disc works fine too, as does the second VBD PCM disc. However, POTC 5.1 16 bit PCM fails to rip with those exact debug messages.
-Edit- The 24 bit stereo PCM auxiliary track in Transformers: Prime S1 rips without a problem...
-Edit 2- The 16 bit stereo PCM audio in Skins S5 is immune too. That's every kind of Stereo passing, all in titles with multiple segments (Play Alls).
Gronnie
#9 Post by Gronnie » Sat Aug 23, 2014 2:45 am
Woodstock wrote:Three posts saying "it doesn't work". Not one offering any information that might be helpful.
Excuse me? I posted a thread with logs and got exactly 0 responses. I then followed up in my thread and another with exactly what the problem is.
Gronnie
#10 Post by Gronnie » Sat Aug 23, 2014 2:46 am
For me Superbad failed if LPCM was selected, and ripped fine if it was not.
ndjamena
#11 Post by ndjamena » Sat Aug 23, 2014 3:20 am
Superbad:
http://www.blu-ray.com/movies/Superbad-Blu-ray/598/
Superbad Blu-ray wrote:English: LPCM 5.1 (48kHz, 16-bit)
And yes, they do work if you deselect the PCM tracks.
wsmeyer
#12 Post by wsmeyer » Sat Aug 23, 2014 4:20 am
It appears there were a couple of threads that got merged so I doubt his comment was directed at you
Warrzone
#13 Post by Warrzone » Wed Aug 27, 2014 11:44 pm
ndjamena wrote:Superbad:
People want the lossless audio though. That's one of the big reasons of using MakeMKV.
ndjamena
#14 Post by ndjamena » Thu Aug 28, 2014 4:49 pm
I was answering Mikes question, not making a suggestion.
