Trend Micro is blocking MakeMKV V1.8.12
jtcc1015
Post by jtcc1015 » Sun Aug 17, 2014 3:58 pm
My Trend Micro is blocking the installation of makeMKV V1.8.12, should I go ahead with the installation anyway?
Re: Trend Micro is blocking MakeMKV V1.8.12
Post by mike admin » Sun Aug 17, 2014 4:12 pm
Check the SHA sums then, files are clean:
https://www.virustotal.com/en/file/a1d8 ... /analysis/
https://www.virustotal.com/en/file/06a7 ... /analysis/
djwilf
Post by djwilf » Thu Aug 28, 2014 9:59 am
I am seeing the same sort of issue when installing 1.8.12
When I use the about, I see that the GUI is 1.8.12 but the program is still 1.8.11.
When I check the SHA, it is not what is published. Should this be the zip or .exe ?
