Anyone had luck with the Muppets Most Wanted BD? Getting the following error with .11:
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/01071.m2ts' at offset '168689664'
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/01071.m2ts' at offset '168689664
Muppets Most Wanted
Re: Muppets Most Wanted
Those errors are the drive saying it can't read parts of the disk. Not only could it not read one of the sectors, it couldn't find the track after that.
If the disk is new, you should get it replaced. Otherwise, try cleaning it.
