Problem Using MakeMKV
vidner
#1 Post by vidner » Thu Aug 14, 2014 8:15 am
I can't use MakeMKV, because the program tells me I need to update it even though I just did.
Maybe you can help.
BTW, I already tried alot of the common things like complete deinstall and removing the MakeMKV key tree in the registry.
I'm using Windows 7 64 bit.
Newbee
Re: Problem Using MakeMKV
#2 Post by Newbee » Thu Aug 14, 2014 10:19 am
Got the exact same problem.
Brand new user to Makemkv having recently only heard about it. Install Makemkv about 7 days ago, now get the EXACT same message as you. :(
Did the usual things of RegClean and System Restore, but to no avail, same problem as you.
Can anyone help ? Thanks. :)
Moderator ???
Newbee
#3 Post by Newbee » Thu Aug 14, 2014 10:38 am
Ok, just for further information.
Downloaded the program a fresh and installed on a completely different pc.
Program installed ok, but EXACT same error message comes up straight away.
So, problem no on users end.... but with bug in MKV new release file ????
Help anyone
Thanks.
Newbee
#4 Post by Newbee » Thu Aug 14, 2014 10:45 am
Ok, confusing, but found the answer.
I should have read further, ie this post...
As stated on a main page all features of MakeMKV are free while program is in beta. You may purchase the full activation key if you like the program and want to show your support, but you also may use the temporary beta key.
The current beta key is
Code:
T-KJ9wI8L6mOhvdz9BelqS68Y9cXkP2UK9bka2_aTvf2WN3wTKSeuyZUakxL1hsSbSBU
and is valid until end of September 2014. Please check back for updated key on this page.
vidner
#5 Post by vidner » Thu Aug 14, 2014 12:39 pm
Great, thanks!
vidner
#6 Post by vidner » Thu Aug 14, 2014 12:40 pm
But where did you find that post?
Zlaxhe
#7 Post by Zlaxhe » Thu Aug 14, 2014 1:28 pm
